Help With Early Ford Tin Bearing Cover
this thread has 4 replies and has been viewed 358 times
Old 07-02-2019, 04:41:48 PM
rhb-3 rhb-3 is offline
Default Help With Early Ford Tin Bearing Cover
Found what looks like a front wheel bearing hub cover made from light steel with tabs on the rear. There is a Ford emblem and Made in USA. Measures about 2-1/2"OD of tabs. Any help with ID appreciated.
ID:	338418   Click image for larger version
Old 07-02-2019, 05:00:40 PM
Jake Jacobs Jake Jacobs is offline
Default Re: Help With Early Ford Tin Bearing Cover
1926 or 1927 Model T Ford with wire wheels or a 1928 1929 Model A Ford. Would be a hub cap for front and rear.
The Following User Says Thank You to Jake Jacobs For This Post:
Old 07-02-2019, 11:14:47 PM
Bob Shannon Bob Shannon is offline
I would say 30 or 31
Old 07-03-2019, 05:43:45 AM
BHoward BHoward is offline
28 - 29 30 - 31 are bigger
Old 07-03-2019, 07:11:08 AM
DaveHC DaveHC is offline
Yes 28/29 , 30/31 are larger and flatter .
Unknown Early Carburetor Float Cover Craig Gillingham Smokstak Down Under 0 10-13-2017 03:20:51 AM
8N hydraulic top cover not fitting on ford 2N Racsan Antique Farm Tractors 7 11-16-2014 09:22:50 PM
Ford 3000 Lift cover Jim Kennedy Antique Farm Tractors 0 12-23-2012 03:15:25 AM
Early 92 S-242 Segment Gear Cover Hank Czerwick Maytag Engines and Collectibles 2 09-22-2012 08:11:40 PM
Ford 9N timing cover installation Ray Cardoza Antique Farm Tractors 4 04-22-2009 08:23:50 PM
