International 1930's B3-136WP-1-1/2 ton Help!
this thread has 5 replies and has been viewed 465 times
Old 07-09-2019, 07:21:57 PM
Wolfes304 Wolfes304 is offline
Default International 1930's B3-136WP-1-1/2 ton Help!
My boss purchased what he believed was a 1930 International, he has made it into a rat rad. When purchased no title was given and we are having a very hard time getting a title.
I did some research and this seemed to be the place to come I have attached a photo plus I will type it out because it is hard to read. I have a title company willing to help me but I need to be sure of the year of this machine. One thing we swapped the motor out because it was seized. The only numbers I could locate on the motor are as follows - FAB216619 any information you guys can provide would be awesome!
Info on plate which is located around front passenger fender
Model - B3-136WP-1 1/2 TON
Chasis - B3-16234
Body/Cab/Load/Equip - 6250
Chasis Wt - 3928
Total Chasis Wt - 10178
Frt Axle Gro - 2860
Rear Axle Gro - 7650
The Following User Says Thank You to Wolfes304 For This Post:
Old 07-09-2019, 10:18:11 PM
Default Re: International 1930's B3-136WP-1-1/2 ton Help!
That's a rare truck. According to what I can find it was only built for two years...1933 and 1934. The 5 digit serial number would make it a 1934. It appears that it was phased out by 1935 in favor of the more streamlined Model "C" trucks.
ID:	338843   Click image for larger version
The Following 2 Users Say Thank You to Mark Schneider For This Post:
Old 07-09-2019, 11:40:52 PM
Dwayne Fuller's Avatar
Dwayne Fuller Dwayne Fuller is offline
We need pictures of the complete truck, please. B3 1 1/2 tons are not very plentiful. I have a 1933. I think yours is a 1934 by the chassis number. Verify the chassis number on the frame before you proceed with the title. It is stamped on the driver's side frame horn where the front bumper attaches. Please do not scrap the FAB engine, parts are getting scarce.
---------- Post added at 10:40:52 PM ---------- Previous post was at 10:29:54 PM ----------
https://www.smokstak.com/forum/showthread.php?t=97761
If this worked the link should take you to the thread on my truck. I was told my truck was a 1930 when I bought it, also without a title.
The Following 2 Users Say Thank You to Dwayne Fuller For This Post:
Old 07-10-2019, 12:21:26 AM
cornbinder89 cornbinder89 is offline
the FAB is a wetliner engine, worse case remove the rods and pull the piston and liners together. Definitely worth saving. Could have a mag or gear driven generator with the distributor driven off the back of the genny.
I have seen a mag option in literature but never seen one in person. Even the gear driven generators aren't that common anymore.
The Following User Says Thank You to cornbinder89 For This Post:
Old 07-11-2019, 10:23:40 AM
https://oldihc.wordpress.com/
Old 10-05-2019, 09:55:44 PM
Monsonmotors Monsonmotors is offline
I own one. It’s an unusual truck, but probably more because it had wood in the cab and therefore the cabs imploded over time.
I started mine and all the neighbors ran over. Quite the exhaust sound!
It’s the “depression” version of the IHC A series. The A series had
more brightwork and a lot more models. B just had B-3 and B-4.
Mine evidently was not driven much as the shackle pins showed no wear and no slop in the kingpins. And it started!
You are giving your DMV too much credit. They wouldn’t know a B-3 if it fell on them. If your boss insists on running International name plates then just buy a cheap, newer IHC and tag it as that.
Laugh at CA all you want. We have no such tagging issues.
Case l 1930 tristan e Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 06-02-2017 08:27:08 AM
1930 IHC truck Dwayne Fuller Antique Autos and Trucks 19 04-12-2013 03:15:36 PM
1930 Mack BL Corey Robinson Antique Autos and Trucks 1 09-05-2012 01:02:07 AM
1930's IH coil bad? chade1968 Hit & Miss Gas Engine Discussion 1 08-26-2012 11:41:28 PM
1930 Reo Car Dave Preuhs Antique Autos and Trucks 4 05-10-2012 09:18:20 PM
