fuel cap gasket
this thread has 17 replies and has been viewed 609 times
Old 07-29-2019, 04:39:28 PM
pigpen60 pigpen60 is offline
Default fuel cap gasket
What do you use to replace the fuel tank gasket?
Old 07-29-2019, 04:56:53 PM
Mike in NC's Avatar
Default Re: fuel cap gasket
I have cut them out of cork.
SmokStak Member #28
Old 07-29-2019, 05:15:17 PM
Cool, I have a roll of 1/8" cork gasket material. Do you use adhesive or let it float.
Old 07-29-2019, 06:01:10 PM
Mike in NC's Avatar
I just cut it to where it is snug inside the cap and let it float.
SmokStak Member #28
Old 07-29-2019, 07:02:26 PM
Thank you!
Old 07-29-2019, 11:19:41 PM
gdstew gdstew is offline
Or you can use rubber, just make sure it is vented
Old 07-30-2019, 07:56:43 AM
Leonard Keifer Leonard Keifer is offline
With either the cork or the rubber put a piece in gasoline first to make sure it's compatible with gasoline. Some of the newer "cork" is actually cork bits glued together. Some types of rubber swell and rapidly deteriorate/dissolve in contact with gasoline.
I had some nice thick rubber I thought would make a nice gas cap gasket, put some in gasoline first and it fell apart.
The Following User Says Thank You to Leonard Keifer For This Post:
Old 07-30-2019, 09:32:51 AM
Good to know. Will do the soak test.
Old 07-30-2019, 12:23:49 PM
Would leather work ? leather used to be used to make oil seals.
Old 07-30-2019, 01:08:00 PM
Not well, it cracks with age and shrinks when exposed to gas. If you cant find good cork, you might try velum gasket material.
Old 07-30-2019, 03:17:27 PM
Ken Karrow Ken Karrow is offline
I use gasket material like Andrew, poke a little hole in it off to one side so that tank can vent. Cap gasket is basically just to keep gas from splashing out due to vibration. Tip of ice pick size hole is right.
Old 07-30-2019, 04:16:21 PM
Tracy T Tracy T is offline
leather use to be a common component used for the accelerator pump seal, rubber was NEVER used in or around gasoline! often people will refer to the neopreme fuel lines as rubber but they are not rubber.
Old 07-30-2019, 06:14:47 PM
Thumbs down Re: fuel cap gasket
With todays crap E-10, neoprene is no good either. The alky in E-10 eats it!
Yes, when gas was gasoline, leather was used. todays gas is a mix of volotile gasses, a little gasoline and a lot of additives. Shouldnt call it gasoline anymore - it isnt!
Old 07-30-2019, 07:36:27 PM
Bolens 1000 Bolens 1000 is offline
For the small wisconsin & briggs with saber style cap I had a bunch remade ethanol resistant rubber
https:///w...c87-and-69961/
Old 07-30-2019, 07:40:41 PM
Bolens 1000 Your link isnt working.
Old 07-31-2019, 11:25:47 AM
Fred M. Fred M. is offline
This web page is messing things up!
Remove one / and insert before wisconsin:
b o l e n s p ar t s a n d s u p p l i e s . com /
(without the spaces)
Fred
Old 07-31-2019, 01:50:44 PM
Power Power is online now
When they started putting alcohol in gas, the rebuild kits came with neoprene plunger seal boots
Old 07-31-2019, 08:13:50 PM
I soaked a piece for 24 hrs and it held up.
L634 Fuel Line Fitting Type Between Fuel Filter and Pump? Birken Vogt Onan Generators 4 08-22-2015 06:38:07 AM
2-71 loss of fuel pressure from fuel tank-check valve? or bad fuel pump? Walter J. Generators & Electric Motors General Discussion 18 08-24-2011 09:22:40 AM
Filtration: Fuel Strainer? Anyone have a Photo of F/M fuel-line FUEL STRAINER? DerekC Hit & Miss Gas Engine Discussion 1 11-17-2007 06:10:01 PM
Need 2 piece fuel tank gasket sealer advice Kenn K Hit & Miss Gas Engine Discussion 8 01-21-2007 10:00:19 PM
PERMATEX vs. paper gasket vs. other gasket material MarkP Small Air Cooled Gasoline Engines 1 04-19-2006 08:18:24 AM
