Looking for Best/Cat 60 crankshaft gear
this thread has 5 replies and has been viewed 500 times
Old 08-04-2019, 02:21:30 PM
flyguy5219 flyguy5219 is offline
Default Looking for Best/Cat 60 crankshaft gear
Helping an elderly friend with his Best 60.
He needs a crankshaft timing gear.
Anybody out there have a decent one for sale?
Old 08-09-2019, 11:29:23 PM
Default Re: Looking for Best/Cat 60 crankshaft gear
Anybody....??
Old 08-10-2019, 12:22:21 AM
Alastair Geddes. Alastair Geddes. is offline
Well you can ask and see but since they are getting on now i suggest he look into making a new one from scratch.
I would think there are gear making companies over there who could make one for him.
The Following User Says Thank You to Alastair Geddes. For This Post:
Old 08-10-2019, 08:35:46 AM
Doug Tallman Doug Tallman is offline
Check into getting a gear blank and getting the keyway broached.
The Following User Says Thank You to Doug Tallman For This Post:
Old 08-10-2019, 08:43:21 AM
Gene Williams Gene Williams is offline
You might post this over on ACMOC.org or try antiquecrawlerparts .com
The Following User Says Thank You to Gene Williams For This Post:
Old 08-10-2019, 11:39:57 PM
casertractor casertractor is online now
www.antiquecrawlerparts.com
The Following 2 Users Say Thank You to casertractor For This Post:
VH4D Crankshaft Gear 2bobcats Wisconsin Engines 13 08-17-2017 08:48:18 PM
Case 50 Crankshaft Pinion Gear Weld Engineer Steam Stationary Engines, Traction Engines 48 02-24-2016 07:08:16 PM
Briggs ZZ crankshaft gear flywheelerjohn Small Air Cooled Gasoline Engines 1 07-27-2014 12:14:50 PM
Baker Monitor crankshaft gear DustyBar Hit & Miss Gas Engine Discussion 5 02-14-2013 05:52:45 PM
20 hp Keck Crankshaft Gear CJKlossner Steam Stationary Engines, Traction Engines 2 10-29-2011 12:17:14 AM
