1925 Rumely M
this thread has 13 replies and has been viewed 1300 times
Old 08-06-2019, 08:02:33 PM
DanLyle89 DanLyle89 is offline
Default 1925 Rumely M
Hi I’m restoring a 1925 Rumely model M. I am looking for the gasoline tank priming pump assembly and any diagrams on how the fuel lines were ran on it. Also looking for the glass for the lubricator have went through it just the glass is broken. Thank you for any help.
The Following User Says Thank You to DanLyle89 For This Post:
Old 08-06-2019, 10:05:09 PM
casertractor casertractor is online now
Default Re: 1925 Rumely M
Some parts sources
www.salvagetractors.com
www.rumely.com
Glass for the lubricator
www.mcmaster.com
Parts and operators manuals can be found on ebay and/or Amazon
Old 08-06-2019, 10:07:47 PM
CBarth66 CBarth66 is offline
I got a glass for my Manzel lubricator from Romo machine in NY. They probably still sell them.
The Following 2 Users Say Thank You to CBarth66 For This Post:
Old 08-12-2019, 07:36:33 PM
Finally figured out how to post pictures lol
ID:	341281   Click image for larger version
Old 08-12-2019, 09:40:49 PM
Nice original tractor Dan.It would be a shame to restore that one i would just try to get it running or atleast get it running better then it is depending on what the situation is with this tractor.With the priming tanks most folks dont actully use them they just hook them up for show.Does your tractor have the "Last Vendors" tag on the left fender?
The Following 2 Users Say Thank You to casertractor For This Post:
Old 08-12-2019, 11:34:18 PM
Yes it does have that tag! I have the history of the tractor since new when it started its life in Saskatchewan original receipts and manual. It is close to running but not there yet
Old 08-12-2019, 11:36:00 PM
Good to see the original galvanized cyclone air cleaner is still with the tractor
Old 08-13-2019, 09:21:12 AM
halcon halcon is offline
That pump in the starting tank is a "DOLE" pump, Many of the larger cars from back in the 1920s had one mounted in the dash to give them a shot of gas for starting, they were on Oldsmobile, Chrysler, Pontiac, and others, If you check with some one who collected up old car stuff of that vintage you might find one.
The Following 3 Users Say Thank You to halcon For This Post:
Old 08-13-2019, 09:59:44 AM
Your tractor must have been shipped thru from the warehouse in Saskatoon from La Porte?.Could you post the bill of sale and manual ? as we would like to see those iteams
Old 08-13-2019, 02:16:21 PM
Awesome thank you!
Old 08-13-2019, 04:22:15 PM
Norm Johnston Norm Johnston is offline
A couple of years back when I restored my M model those Dole pumps were available through War Birds restorations in the USA. they were new old stock, you may have to source new plunger washers to replace the original ones as they were dried up and failed quickly. I found a hydraulic service who provided these for me.
The Following 2 Users Say Thank You to Norm Johnston For This Post:
Old 08-13-2019, 04:46:21 PM
https://www.ebay.com/itm/antique-car...wAAOSwkV1bgp6Q
https://www.ebay.com/itm/Fuel-primin...4AAOSwC~1a8Fv~
Old 08-13-2019, 11:59:09 PM
Military vehicle's and war planes had them also
Old 08-14-2019, 02:13:33 AM
Ray Slabaugh, Nappannee, Indiana, is still making them.
574-773-0667
1925 Arco 2hp JohnDeere80 Hit & Miss Gas Engine Discussion 3 04-09-2018 05:54:15 PM
1925 Economy before and after Dale Barnett Hit & Miss Gas Engine Discussion 6 09-25-2016 09:10:13 PM
RUMELY-OLDS Rumely Products Co., La Porte Imdiana. Denis Rouleau Hit & Miss Gas Engine Discussion 8 02-15-2014 11:38:44 AM
1925 IHC M Oiler jboyer1028 Hit & Miss Gas Engine Discussion 3 04-22-2013 10:03:57 PM
International 1925 M Jerry B Hit & Miss Gas Engine Discussion 1 03-31-2008 07:39:33 AM
