1919 titan 1020 air valve
this thread has 1 replies and has been viewed 391 times
Old 08-09-2019, 03:23:19 PM
barry ayres barry ayres is offline
Default
hi
does anyone have a picture/ diagram of what should be in the air valve assy in the elbow on top of mixer. i am guessing there should be a spring loaded disc possibly with leather washer that seats lightly onto ring cast into elbow.
many thanks barry
The Following User Says Thank You to barry ayres For This Post:
Old 08-10-2019, 08:01:19 PM
Roger Byrne's Avatar
Roger Byrne Roger Byrne is offline
Default Re: 1919 titan 1020 air valve
Barry, below is a drawing of what the proportioning valve looks like. The bottom spring is fairly light and the upper one is about twice as strong. The disk is generally set in the center, to the lower center range of the opening to start with. Then you adjust it to the performance of your tractor. I hope this helps.
Name:	Titan air comp valve.jpg
ID:	341150   Click image for larger version
Name:	Tiatan valve 2.jpg
ID:	341151   Click image for larger version
Name:	Titan valve 3.jpg
Preserving Mechanical History for Future Generations since 1965
The Following 5 Users Say Thank You to Roger Byrne For This Post:
1919 titan 1020 air valve barry ayres Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 08-09-2019 03:10:46 PM
IHC Titan 1020 Alan R Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 15 07-22-2018 08:09:22 PM
Titan 1020 Alan R Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 11-30-2017 08:25:00 PM
Titan 1020 spark plug and air cleaner melonreo Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 07-18-2016 09:30:15 AM
Mccormick Deering 1020 Valve Seats Don Campbell Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 10-29-2011 05:45:53 PM
