18-36 Hart Parr ConRod Cracks
this thread has 25 replies and has been viewed 1751 times
Old 08-15-2019, 09:42:05 PM
steelwheelrat steelwheelrat is offline
Default 18-36 Hart Parr ConRod Cracks
Putting an engine together and stumbled upon something rather concerning. Both of the connecting rods I have what appear to be identical cracks. Has anyone run into this???
They are as close to identical as it gets. My first inclination is to assume they are a defect something akin hot tears in castings but they are deeper in the heavier mass than you would normally see in casting hot tears. Witness Mark's say the rods came out of different forging dies. Any insight?
ID:	341541   Click image for larger version
ID:	341542   Click image for larger version
ID:	341543   Click image for larger version
The Following 3 Users Say Thank You to steelwheelrat For This Post:
Old 08-15-2019, 11:01:18 PM
Greg Mosley Greg Mosley is online now
Default Re: 18-36 Hart Parr ConRod Cracks
Greetings Steelwheelrat, A few ideas. (1) Metal fatigue from age,
(2) over tightening pinch bolt to compensate for pin eyelet bushing to wrist pin wear. (3) pin eyelet slapping from being too loose (4) pin eyelet tolerance to tight at one time. Glad you found it during inspection. Enuf Said.
The Following User Says Thank You to Greg Mosley For This Post:
Old 08-15-2019, 11:37:21 PM
Jeff Blaney Jeff Blaney is offline
It is difficult to see in the pictures, do the cracks extend all the way to the flat where the head of the bolt seats?
The Following User Says Thank You to Jeff Blaney For This Post:
Old 08-15-2019, 11:42:31 PM
Looks like they have been cut?
Old 08-16-2019, 07:32:15 AM
Wayne Riedlinger Wayne Riedlinger is offline
Sure looks like somone cut them to me also. But Why?.
The Following User Says Thank You to Wayne Riedlinger For This Post:
Old 08-16-2019, 08:32:17 AM
Stuart Landry Stuart Landry is offline
Hi, I think this cracking is caused by side to side slapping of conrod, ( can see heavy wear on side face in pictures )
Which in tun , could be caused by end float of crankshaft ,
Badly worn or out of Parallel crank pins ,
cylinder out of square with crankshaft,
Hope this helps ,
The Following User Says Thank You to Stuart Landry For This Post:
Old 08-16-2019, 10:27:17 AM
Bubbles Bubbles is offline
Those cuts are supposed to be there, it allows the screw to slightly compress the material. The poster is talking about the hairline cracks in between the paint marks.
The Following 2 Users Say Thank You to Bubbles For This Post:
Old 08-16-2019, 11:48:14 AM
Defects as consistent as these cracks generally indicate that there is an issue with the design, metallurgy or manufacturing process. I was curious if anyone else had seen this particular crack in 18-36 Hart Parr rods. With the wealth of knowledge and experience that the Stak community has and the popularity and survival rate of this particular model, I was hoping that if this was a benign issue, someone would have seen it before. I threw the rods on a mag machine this morning and the visual indication is confirmed as a crack in identical locations and lengths on both units.
In modern engines, defects like this are common. Some are benign and others are catastrophic if not repaired. No one ever wants to see a rod turn loose and an antique engine go boom so caution and research are mandatory. Engine booms can be entertaining at the drag strip or at the hotrod tractor pulls but obviously, these parts are slightly more difficult to obtain than say, a 5.9L Cummins or a 9.0L Cursor Iveco like the one in the picture. The last thing I want this to do is end up looking like the one in the picture.
Thanks for the input everyone, I think I repair the cracks before I use them.
ID:	341554   Click image for larger version
ID:	341559   Click image for larger version
The Following 4 Users Say Thank You to steelwheelrat For This Post:
Old 08-16-2019, 12:52:29 PM
That is interesting that the crack does not run all the way to the edge of the rod. If they weren't there from the very beginning, I would guess they are a result of tensile stress placed on the rod caused by excessive wrist pin clearance. The pistons may have been slapping back and forth in line with the rod at TDC and at the bottom of the stroke, pulling and compressing the small end of the rod?
Just a guess!
Old 08-16-2019, 02:03:23 PM
Russ Hamm's Avatar
Reminds me of this famous image from awhile back, haste prevented proper torque on the main bearing caps and the crank was pushed out.
The Following 3 Users Say Thank You to Russ Hamm For This Post:
Old 08-16-2019, 07:49:28 PM
I forgot how many Hart Parr engines I did but I never saw anything like that.
Old 08-18-2019, 06:32:37 PM
Jon Nessel's Avatar
Jon Nessel Jon Nessel is offline
...with a gentle nudge from the aluminum thingy poking out of the hood. Must be a Chevy... or was🤪
Old 08-19-2019, 09:06:18 AM
354 chrysler
Old 08-19-2019, 10:03:20 AM
Russ Hamm's Avatar
Originally Posted by I like oldstuff View Post
354 chrysler
I was thinking 392, and from what I can remember reading about the history of this car, that block was saved, although never in that car again.
Old 08-19-2019, 01:20:09 PM
Originally Posted by Greg Mosley View Post
(2) over tightening pinch bolt to compensate for pin eyelet bushing to wrist pin wear. .
I'll go out on a limb and agree with Mr. Mosley as this for a cause.
We'll never know what happened in the past. The over tightening could have been combined with an over-speed event also?
Good that the cracks were discovered now, and anything more serious prevented.
The Following 2 Users Say Thank You to G Willikers For This Post:
Old 08-19-2019, 11:57:18 PM
Duey C Duey C is offline
How many other running/working Hart-Parr rods have these very same cracks is my noodling? Very interesting thread rat!
Old 08-20-2019, 12:21:20 AM
Jon Nessel's Avatar
I know I'll be taking a real good look at mine 'for it goes back together. Hope JB didn't sell me a lemon!
Old 08-20-2019, 12:49:45 AM
I don’t think it’s a Hart Parr flaw, I’ve worked on a few and never saw cracks like that. I haven’t seen any grenaded Hart Parr’s either. I have a pair of 18-36 Model G rods on my bench now and no cracks on them. I think that one had a rough experience and luckily was found before it came apart.
The Following User Says Thank You to David Hoover For This Post:
Old 08-20-2019, 10:16:26 AM
David, could you do me a favour?
I would like to know the journal diameter and journal width on those Hart Parr connecting rods. Also, what is the center to center distance from throw to wrist pin? I am considering re-purposing some connecting rods for another project.
The Following 2 Users Say Thank You to Jeff Blaney For This Post:
Old 08-20-2019, 10:40:25 AM
Sure, I’ll check tonight.
Hart Parr 15-30A value? smcmanus Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 63 10-04-2016 09:49:43 PM
Hart Parr 40-80 rob hart parr Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 43 09-24-2015 10:39:43 PM
Hart Parr 15-30A Pat Bayer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 19 05-31-2015 11:16:58 PM
Hart Parr taylorjisa Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 03-29-2014 05:35:11 PM
28-50 Hart Parr peterson1 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 09-01-2010 07:53:07 AM
