John Deere "D" steering sectors
this thread has 5 replies and has been viewed 436 times
Old 08-24-2019, 11:11:05 PM
Inter Bloke Inter Bloke is offline
Default John Deere "D" steering sectors
Just wondering what year John Deere "Ds" changed from the fine tooth steering sector to the coarse tooth sector ?
A friend and I between us have 4 sets of steering gear worm and sectors, three are coarse tooth and one is fine tooth. I have what was originally a spoker, 1925 D with a coarse tooth steering and a parts 27 with coarse tooth, he has a 28 with a coarse tooth sector and a parts axle and a few other bits that are fine tooth. It's my understanding that the finer tooth steering was used first and that the coarse tooth came later, just need to find out if this "IS" correct or not and what time the change occurred so we can put the right parts in the correct place.
Thanks Blokes
Graham
Old 08-26-2019, 10:26:04 PM
LukeSte LukeSte is offline
Default Re: John Deere "D" steering sectors
Yes, fine tooth was first...
The Following User Says Thank You to LukeSte For This Post:
Old 08-27-2019, 06:00:32 AM
Thanks Luke,
Any idea what year they actually changed ?
Old 08-27-2019, 09:33:35 AM
ronm ronm is offline
SN 95900- early 1930.
Smokstak member #442
Old 08-27-2019, 02:46:07 PM
Dave16405 Dave16405 is offline
The D58R steering segment gear, which was the "fine tooth" one, was used from 30400 - 95900. The "coarse tooth" segment gear, D1535R, was used from 95901 - 109943. Each segment gear was also used with different matching worm gears.
The Following User Says Thank You to Dave16405 For This Post:
Old 08-28-2019, 09:00:23 AM
Thanks Luke, Ronm and Dave !
I think that's all I needed to know for the moment, it gives us an idea of what we have and how to proceed.
1929 John Deere "D" Replaced Needle and Seat on DLTX 3 Carb bmklawt Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 08-21-2018 08:07:30 PM
1941 John Deere B, "HOLLYWOOD B" Full Exhibition Hollywood B Smokstak Forums Meet and Greet 1 04-14-2015 09:43:17 PM
Timing "Wico C" on a John Deere B (1942) jwhitmor Magnetos, Ignition Coils and Spark Plugs 5 11-15-2013 11:49:43 AM
Help!! I need some advice on a John Deere slant dash "A" electrical system!! Brad73 Antique Farm Tractors 5 08-10-2012 09:03:44 PM
John Deere "Patio Series" Mowers Jonathan Widelo Garden Tractors and Mowers 1 08-02-2005 01:26:11 AM
