18-36 Hart Parr help needed
this thread has 32 replies and has been viewed 1972 times
Old 08-25-2019, 07:34:30 PM
Dustin D Ehli Dustin D Ehli is offline
Default 18-36 Hart Parr help needed
Guys, picked up this tractor recently, overall decent condition, but there's a couple things I'm wondering if anyone can help us out with.
First, the 2 gears that are on the main shaft into the trans are beat up, for sure the one that runs high hear will have to be repaired or replaced. Does anyone have a parts transmission laying around??
Second the belt pulley is homemade so we are looking for one, and the hub is cracked, so that needs to be replaced or repaired.
I believe it's a 1929, 3 speed trans, has clutch brake on the pulley hub.
Thanks for any leads on parts.
Dusty
ID:	342209   Click image for larger version
ID:	342210   Click image for larger version
Having a blast preserving the past.
My Youtube Channel
The Following 7 Users Say Thank You to Dustin D Ehli For This Post:
Old 08-25-2019, 07:50:32 PM
Default Re: 18-36 Hart Parr help needed
We are also looking for an air cleaner
---------- Post added at 06:50:32 PM ---------- Previous post was at 06:37:33 PM ----------
My Youtube Channel
The Following 5 Users Say Thank You to Dustin D Ehli For This Post:
Old 08-25-2019, 09:31:02 PM
I should say that I won't have time till this winter to take the trans apart, so I don't know the gear size or tooth count or anything but know that I need the gear that runs high on the main shaft, and if it's available, the other gear on the main shaft.
I'm assuming all 3 speed 18-36 trans are the same.
My Youtube Channel
The Following User Says Thank You to Dustin D Ehli For This Post:
Old 08-25-2019, 10:31:20 PM
Jon Nessel's Avatar
Jon Nessel Jon Nessel is offline
Looks like a decent unit. Looks to be a John Deere carb grafted on as well. The correct Scheblers come up for sale from time to time if you have the mind to change it out at some point. Seems to run fine with the dltx on it.
Old 08-25-2019, 11:48:19 PM
Alan Svanes Alan Svanes is offline
My thanks button is not available, so thanks for posting the video and good luck finding parts.
Alan
Old 08-26-2019, 12:09:51 AM
Lyle S Lyle S is offline
Dustin I have a complete transmission and other parts. Call me at 319-766-2663.
Lyle
The Following User Says Thank You to Lyle S For This Post:
Old 08-26-2019, 08:59:15 AM
I’ve heard the transmissions and crankcases on the Hart Parrs are Babbitted in place. Is this correct?
Old 08-26-2019, 09:02:52 AM
Brian Flatmoe Brian Flatmoe is offline
We have a 28-50 trans that the case is busted up but I believe the gears are ok. Don't know if it is the same or not.
Old 08-26-2019, 09:37:15 AM
VossD VossD is offline
Yes, the bolt holes are filled with babbit after the cases are lined up
Old 08-26-2019, 06:28:43 PM
Duey C Duey C is offline
Runs really nice!
I have a friend: If he were on the net, I'd show him this video and listen for the screaming from 50 miles away, I'd hear him. He'd just flip out over a JD carb on the Hart-Parr.
Thanks for showing this!
Old 08-26-2019, 09:40:46 PM
Update, I have the correct carb if you guys are wondering, I'll look into putting it on during the work this winter, for the mean time it runs good with the JD carb.
Does anyone have a pic of how the air cleaner should look? Or what it's internal construction is? I'll maybe try to fabricate something myself that looks close.
Thanks for the leads in parts so far
My Youtube Channel
Old 08-27-2019, 07:16:50 PM
Camerons's Avatar
Camerons Camerons is offline
You might check with Biewers, i think they had reproduction air cleaners listed for Hart Parr's at one time.
https://salvagetractors.com/
Old 08-28-2019, 04:47:20 PM
Was able to find the gears I was looking for, and the tin that goes over the belt pulley.
Still looking for leads on the hub and belt pulley.
And an air cleaner.
Thanks everyone
My Youtube Channel
The Following 2 Users Say Thank You to Dustin D Ehli For This Post:
Old 08-28-2019, 09:32:27 PM
Another question.
The radiator looks to be in pretty good condition, but rust chunks have come off the top tank and other crap has plugged 90 percent of the core, is there anything I can use to try to loosen it up that won't ruin tbe core or make it leak?
My Youtube Channel
Old 08-29-2019, 09:27:45 AM
Russ Hamm's Avatar
Best luck I have ever had was to disassemble and clean out with air pressure both ways. I sandblast the tanks, etc.
Old 09-02-2019, 03:03:16 PM
Another question, how do you take the small gear off the end of the cam that drives the oiler gear. And does anyone have a good spare?
My Youtube Channel
Old 09-02-2019, 10:00:01 PM
You must not have read your email yet...….
The gear is screwed into the end of the cam shaft...….left hand threads.
Old 09-09-2019, 05:28:37 PM
Does anyone have good pictures of the inside of an original air cleaner, I will probably try to just reproduce one myself but want to see inside it.
All I have is pics of the outside.
Thanks.
My Youtube Channel
Old 09-09-2019, 06:27:47 PM
Pretty hard to get a pic, but this is looking down from the top. You might get some patent descriptions or a drawing if you search the numbers.
ID:	343603   Click image for larger version
The Following 2 Users Say Thank You to David Hoover For This Post:
Old 09-09-2019, 08:35:02 PM
Thanks David, so the elbow Inside leads to the carb I'm assuming.
Air comes in and passes through the fan plate, then up the elbow into the carb.
Is there a way in the bottom to clean it out
My Youtube Channel
16-30 Hart Parr Part Needed Kelly Barnett Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 07-12-2018 08:52:44 AM
Hart-Parr 30-60 Engine Information Needed Elden DuRand Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 29 01-10-2015 03:23:35 PM
Oliver Hart Parr Timing Gear Help Needed Tony Thompson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 05-29-2013 10:56:17 PM
30-60 Hart Parr's Chris Epping Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 06-03-2011 11:49:20 PM
18-36 hart parr help needed Mtype Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 09-23-2006 08:42:18 AM
