Fordson N; intake manifold leak holes
this thread has 2 replies and has been viewed 339 times
Old 08-27-2019, 03:18:52 PM
veroude veroude is offline
Default Fordson N; intake manifold leak holes
I am working on a (English) Fordson N engine, year 1940.
The normall English Kingston MD manifold is on.
Just before the 2 inlet pipes are going into the cylinder block, there are 2 leak holes to let out to much gasoline.
When running the little valves closing automaticly because of the vacuum.
Though when running and I put my finger on I can feel the vacuum a little, so they have a little leak...
How "close" this little valves have to be ...??
Are new ones for sale somewhere....?
thanks! Marco
Old 08-30-2019, 09:32:00 PM
Butch Howe Butch Howe is offline
Default Re: Fordson N; intake manifold leak holes
Remove them and install pipe plugs.
The Following User Says Thank You to Butch Howe For This Post:
Old 08-31-2019, 03:41:20 AM
RoFoCo RoFoCo is offline
Hi
I find that the engine will flood very easily if they are blocked/removed. They tend to get carboned up over time, and the valve stops seating properly.
Take them off, and soak them in carb cleaner, and clean as much as possible. This often works.
Thanks, Roger
The Following 2 Users Say Thank You to RoFoCo For This Post:
Fordson F 1919 with Fordson E27N Manifold and Zenith Vaporizer/Carb hkruger Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 07-03-2018 03:23:23 PM
Unknown Car Intake Manifold joder Antique Autos and Trucks 0 12-03-2017 08:46:37 PM
Looking for info on Odd Intake Manifold blacktinlizzie Unidentified Engines 4 10-10-2017 07:17:41 PM
Onan 5.0 CCK Intake Manifold Leak Robert S. Onan Generators 9 07-16-2010 03:08:30 PM
