Rumely 15-25 L intake needed
this thread has 5 replies and has been viewed 462 times
Old 08-27-2019, 08:48:51 PM
CBarth66 CBarth66 is offline
Default Rumely 15-25 L intake needed
I am still looking for a cast iron air intake pipe with the choke lever for my Rumely 15-25 L It's the one from the carb to the air cleaner. I have a new recast one for a model W that I was going to have cut and machined down, but would rather have an original. I will trade this one or just purchase. PM me or email on this site. You can also call or text me at 740-350-1524 Thanks.
Old 09-09-2019, 01:37:38 PM
Harry Henderson Harry Henderson is offline
Photo Re: Rumely 15-25 L intake needed
Hello, I might have what you need. But I’m no Rumley expert so check the photos and see if that works? It came with some Titan parts. It’s here in the UK but shipping is no problem.
See what you think.
Harry
ID:	343582   Click image for larger version
ID:	343583   Click image for larger version
ID:	343584   Click image for larger version
The Following User Says Thank You to Harry Henderson For This Post:
Old 09-09-2019, 01:59:06 PM
Default Re: Rumely 15-25 L intake needed
Thanks for the reply Harry. No, that's not the one I need. Mine should not have a heat diverter valve on it and should have a 90 degree curve on top with the choke lever. I have a model W exhaust manifold for sale that your intake may have been used with. I'll try to get the casting # of the pipe I need on here soon. I appreciate your trying to help me Harry.
The Following User Says Thank You to CBarth66 For This Post:
Old 09-09-2019, 02:05:47 PM
Ah OK, is what I have from a Rumley W?
Old 09-09-2019, 02:59:43 PM
I'm not sure. With your casting # on there someone should be able to tell you what it's for.
Old 09-09-2019, 06:35:04 PM
Harry, that part you have is for a Rumely L like mine. I just looked it up in my parts book. It is called an air regulating body. Must have been for the ones that had the shields over the exhaust manifold to draw warm air in cold weather. Mine does not have this set up. What I need is called an air cleaner elbow and is part # c5p3171. Pictures show the parts in the book.
ID:	343606   Click image for larger version
ID:	343607   Click image for larger version
The Following 2 Users Say Thank You to CBarth66 For This Post:
Intake valve spring source needed Kevin Weis Hit & Miss Gas Engine Discussion 0 02-07-2016 03:40:37 PM
MEP 003a intake area wire harness needed maddog Military MEP and Aircraft Gen-Sets 0 08-06-2009 03:59:18 PM
Fairbanks Morse-Intake Valve Needed- LShap1777 Hit & Miss Gas Engine Discussion 5 11-27-2008 07:03:15 PM
Intake Valve Help Needed Thierry M. Petersen Small Air Cooled Gasoline Engines 4 09-12-2007 11:40:51 AM
2 Large intake valves needed Earnie Hampton Oil Field Engines & Related Equipment 3 06-28-2007 09:47:30 PM
