Case on a Wall
this thread has 15 replies and has been viewed 1377 times
Old 08-29-2019, 08:31:40 PM
Default Case on a Wall
Well, this is different. Some people, under the influence of a few brews, may have already thought they saw something like this!
It is at a brewery near Forest, Ontario.
Looks like a decent ol' tractor.
Last edited by G Willikers; 08-29-2019 at 08:36:32 PM. Reason: Picture from Ontario Farmer Aug. 20, 2019.
The Following 16 Users Say Thank You to G Willikers For This Post:
Old 08-29-2019, 11:29:26 PM
ulgydog56's Avatar
Default Re: Case on a Wall
well that's one way to store it..
The Following User Says Thank You to ulgydog56 For This Post:
Old 08-30-2019, 09:51:16 AM
ronm ronm is offline
Looks like a Case of bad judgement...
Smokstak member #442
The Following 3 Users Say Thank You to ronm For This Post:
Old 08-30-2019, 10:35:49 AM
ncmercer ncmercer is offline
eMail NOT Working
how is it being held up there? not sure i'd be pouring taps underneath that.
The Following User Says Thank You to ncmercer For This Post:
Old 08-30-2019, 12:15:01 PM
Levitation, if you believe it will stay there, it will.
The Following 3 Users Say Thank You to David Hoover For This Post:
Old 08-30-2019, 03:38:38 PM
Russ Hamm's Avatar
I had a big back seat engineering answer to it, but decided to just say I would be worried and leave it at that.
The Following 6 Users Say Thank You to Russ Hamm For This Post:
Old 08-30-2019, 04:34:58 PM
Jon Nessel's Avatar
Jon Nessel Jon Nessel is offline
Be hell to try to get up there to start it to back it down if you wanted to take it to a show. I'd have parked it the other way around, that way you would have to worry about sliding off the seat!
The Following 2 Users Say Thank You to Jon Nessel For This Post:
Old 08-30-2019, 08:11:57 PM
www.stonepickerbrewing.com
Old 08-30-2019, 08:32:04 PM
fumo fumo is offline
In this CASE it's an off track crawler.
The Following User Says Thank You to fumo For This Post:
Old 08-30-2019, 09:27:11 PM
Old tractors and beer... what’s better than that?
Old 08-30-2019, 09:40:53 PM
Friends have a brewery called the Steel Wheel Brewery near Brantford, Ontario:
https://steelwheel.ca/
They are also old iron collectors. A few weeks back, I helped them with an open house. We ran an X Oil Pull, 20-40 Sawyer-Massey, 30 Hart-Parr, a couple of Acadia gas engines, and steamed corn with a 25hp George White traction engine.
I don't drink but the corn was good, and there was a great supper. Big crowd too.
No tractors hanging off the walls, though!
The Following 5 Users Say Thank You to G Willikers For This Post:
Old 09-05-2019, 10:06:09 AM
eMail NOT Working
that's exactly what i always say David Hoover. someone should have a fall show...."TRACTOBERFEST"!!!! booyaaahhh
Old 09-05-2019, 10:25:04 AM
Russ Hamm's Avatar
Cant have too many tractor shows, not?
We debated this some years ago when the subject of changing a show date came up, the main argument against a fall show was that school is in process then. I told them they should tell that to the folks putting on the state fair every year.
Old 09-05-2019, 02:23:30 PM
Exclamation Re: Case on a Wall
Sure it isnt an optical delusion - scene set up and the tractor shot on the flat, and then the photo turned end up? It would have taken some bracing to hold that tractor on that wall for a while!
Old 09-05-2019, 03:59:29 PM
Jon Nessel's Avatar
Might be right, but then a fella'd have a dicken's of a time pouring a good beer!
Old 09-05-2019, 06:03:30 PM
Gasengin Gasengin is offline
Go to the website http://www.stonepickerbrewing.com/ Can see the tractor in the background under the events tab.
Wall Four Help gbritnell Scale Model Engineering 2 04-18-2018 08:21:08 PM
R-T Wall comes down Patrick M Livingstone Smokstak Down Under 6 02-18-2014 06:40:38 AM
Cylinder wall clearance on Crossmotor Case Robertcat Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 11-30-2006 01:12:11 PM
