Steam Engines
threshing mills
this thread has 1 replies and has been viewed 3209 times
Old 03-29-2006, 06:54:24 PM
todd michel todd michel is offline
Default threshing mills
can enyone tell me the space [min. and max] betwen the cylinder and concaves ?
Old 03-29-2006, 10:06:51 PM
G Willikers G Willikers is online now
Default Re: threshing mills
Not so sure there is hard and fast rule but they run fairly close. Depends on type of grain, condition of grain. Old George White book says use as few teeth as possible in concave. Less teeth for dry grain. More teeth for damp grain. You have to adjust and watch what you are getting out the arse end and elavator. Helps to run at right speed too, keep all teeth tight and strait for they should not hit one another and thresh better when strait. When custom thresh, farmer will usually tell you when you are not doing the good job Gluck haben.
G.
Threshing Mills at Work - Guinness Book of Records. Denis Rouleau Hit & Miss Gas Engine Discussion 0 07-22-2015 06:57:44 PM
old grist mills Edgar Farm Antiques and Collectibles 2 02-24-2012 12:49:44 PM
Grist Mills Mike F Farm Antiques and Collectibles 4 11-07-2010 01:24:51 PM
Is this tool for mills? Ray Cardoza Machine Shop and Tool Talk 9 01-19-2010 11:53:22 PM
Speaking of mills... DanR Farm Antiques and Collectibles 5 02-15-2008 01:14:41 AM
