Paint Shop
Removing paint to get to the original finish
this thread has 1 replies and has been viewed 3689 times
Old 12-24-2006, 12:28:53 PM
Brian Lynch's Avatar
Question Removing paint to get to the original finish
Hi all, Have a question dealing with removing a layer of paint that has been applied to an engine. I have found areas of original paint on the engine where the new layer has peeled off. (there must have been oil or some other agent there that prevented the paint from sticking.) What I want to do is remove all this "new" crap and get it back as close to the OEM paint as possible. Any ideas? Guidance?
Old 12-25-2006, 11:01:30 PM
Doug Kimball's Avatar
Default Re: Removing paint to get to the original finish
Brian,
I've attached a 'before' photo & posted an 'after' photo in this thread:
http://www.smokstak.com/forum/attach...5&d=1150800230
of an Alma Jr. As received I thought there was no original paint at all. I used mineral spirits & the finest steel wool, 0000, that I could find & a wooden stick. The outer layer appeared to be a clay like dust, then a layer of medium blue & then original dark green with gold pinstriping. Apparently they did not clean engine very well before painting the blue & I got about 95% of it off. It was time consuming. When I got done with the spirits the paint was very chalky and whitish. I then coated it with satin polyurethane which eliminated the chalkiness and brought out the color. You can also use 50-50 mix of boiled linseed oil & mineral spirits.
On other engines I have not been as successful, most recently a New Way Jewel. The red paint & gold striping on flywheels cleaned up well but I could not save the dark green on the base that had been oversprayed with black.
Removing Paint from Wood Without Damaging Original barstart Paint Shop 7 06-01-2019 11:57:59 AM
Associated Hired Man~ original finish??? David M. Lyon Hit & Miss Gas Engine Discussion 4 09-30-2009 04:16:35 PM
Original finish is rust. Options? John Drabik Hit & Miss Gas Engine Discussion 8 03-08-2009 05:23:25 PM
original paint finish Garrison Brown Paint Shop 7 01-22-2003 05:14:38 PM
Original Mag Finish??? Bill Nich Antique Engine Archives 2 12-26-2000 08:16:26 PM
