Changing of carburetors
this thread has 8 replies and has been viewed 2462 times
Old 03-28-2008, 09:18:00 AM
Farmboy1 Farmboy1 is offline
Default Changing of carburetors
if you changed carbs from a manual choke (broke) to an autochoke carb what would be the ups and downs the engine runs on the broke manual but you have to have a hex key to keep it open and pour gas in the carb to get it to start then put your hand over the carb til it gets warm then it runs perfect what should i do
Old 03-28-2008, 04:12:17 PM
Jordan's Avatar
Jordan Jordan is offline
Default Re: Changing of carburators
farmboy,
does the carb with manual choke that is broke you are refering to just have a choke plate? if so just remove whats left of it and just cover the carb with your hand and roll the engine over, your hand will act as the choke plate.
jordan
Old 03-28-2008, 04:19:54 PM
Jordan's Avatar
sorry farmboy,
shoulda asked what kinda engine it was on first.
jordan
Old 03-28-2008, 04:31:43 PM
its a briggs that i am going to sell i have bbeen doing what you suggested already
Old 03-28-2008, 04:55:38 PM
Jordan's Avatar
i don't know if your carb is similar to mine on the continetal i have but the choke plate is spring loaded and was most like controlled by a linkage of some sort on the picece of equipment it came off of. sounds like yours may be missing a spring?
jordan
Old 03-28-2008, 07:31:30 PM
if you mean the spring on the carb choke peoce that sticks out yes it is gone as is the peice and the choke plate too
Old 03-28-2008, 07:57:01 PM
Jordan's Avatar
have you tried a local small engine shop to see if they can get you the pieces or a carb kit?
jordan
Old 03-28-2008, 08:34:15 PM
Pyeper Pyeper is offline
Wat model briggs? My type B has an auto choke because its a gen set engine. But it runs fine. So long as the velocity of air through the inlet is sufficient, it will hold the choke open. Assuming yours works on the same system with a weighted choke lever.
Old 03-29-2008, 08:48:53 AM
it is spring operated by the vaccum from the enging. (jordans part) no we dont have any near but even if we did it wouldnt matter i have extra parts might as well use them
Painting carburetors Mark Gross Hit & Miss Gas Engine Discussion 4 01-02-2014 06:59:52 PM
Carburetors Steve Kreiner Hit & Miss Gas Engine Discussion 4 02-10-2012 12:57:10 PM
Tecumseh Carburetors Oberon67 Small Air Cooled Gasoline Engines 5 04-21-2010 10:16:42 PM
Unknown Carburetors Kevin Stone Hit & Miss Gas Engine Discussion 4 02-08-2010 08:01:42 AM
Keihin Carburetors Bill Sherlock Small Air Cooled Gasoline Engines 8 06-20-2008 10:32:43 AM
