Good place to buy a impact screw driver
this thread has 11 replies and has been viewed 3169 times
Old 04-20-2008, 03:37:51 PM
Walt in Jaxn Tn. Walt in Jaxn Tn. is offline
Default Good place to buy a impact screw driver
I had a impact screw driver years ago and it was very usefull, It was a must for working on Japanese motorcycles. It was a cheap brand and the bits shattered after a few years and I lost track of it. I'd like to find another. Auto parts store? Also, does anyone sell friction tape? seems like all that is available is plastic or duct tape? I covered an old tractor steering wheel with rubber tape (CTB-15 tape, self amalgemating) we use it in the cable tv business to wrap aerial cable connectors to weather proof. I want to cover the rubber tape with friction tape.
--Walt--
Impact Screwdrivers on eBay
Old 04-20-2008, 04:05:23 PM
Chris Page
Default Re: Good place to buy a impact screw driver
Try Lowes they have thousands of different products
CHRIS
Old 04-20-2008, 07:06:33 PM
Sky
For the impact driver i would go to sears and get the craftsman type. I have 2 myself. ya you pay probably a little more for one but your buying a tool there thats tuffer then a peice of steel.
Old 04-20-2008, 07:09:41 PM
Elden DuRand's Avatar
Walt:
The impact drivers are fairly common at the tool sales (also known as "junk" sales).
You can get old fashioned friction tape (the cloth tape with the gooey stickum) at McMaster-Carr.
Mcmaster.com
Take care - Elden
http://www.oldengine.org/members/durand/
Old 04-20-2008, 07:11:47 PM
Sky is right!I have been working on jap bikes for 35 years,and the craftsman I bought then is still going strong.
Old 04-20-2008, 10:41:45 PM
Thumbs down Re: Good place to buy a impact screw driver
I have a 3/8" MAC tool driver that is over 35 years old - it still works fine. I, however cannot find replacement hammer driver phillips bits! I have tried several sources, including MAC, Sears, Loews, and the Home Despot, and everybody wants to sell you a new driver and kit. I DON"T NEED ALL OF IT! I just need the phillips bits, and 1 allen Key bit I broke last summer.
Old 04-20-2008, 11:03:06 PM
greysteam24hp's Avatar
greysteam24hp greysteam24hp is offline
Mac tools do not make their own tools. Mac bought out from a major company. We have two full time electric and air tool repair tools coming in daily. Thousand of them in plant. Use mostly Chicago Pneumatic (CP) or Ingersoll Rand same part combinations as much like Mac. Mac bought out Stanley some years ago. Often times employees not thinking straight using air tool using like a hammer or postponed use oil. We buy from air tool or electric tool parts supplier any makes.
Find your local parts supplier.
Old 04-22-2008, 04:40:34 PM
Sky, I bought one from Sears today, on sale, $21.95 after tax. It's a Craftsman with 4 bits. 3 phillips and 1 slot. I need a smaller slot than is in the set to loosen the set screws that hold the coil core in place on my F.M. FMX2B6D magneto. I've had the magneto set screws soaking with PB Blaster for a couple of weeks now.
--Walt--
Old 04-22-2008, 05:24:36 PM
TheToolman's Avatar
TheToolman TheToolman is offline
Wink Re: Good place to buy a impact screw driver
I bought my last one from the MATCO tool truck "TOOLMAN" (I'm retired now)
Old 04-22-2008, 06:40:51 PM
dightonford dightonford is offline
I got this one from NAPA, part # SER 1140
Works great, Josh.
Old 04-22-2008, 09:16:19 PM
--Walt--
The Craftsman impact driver is (or was) a good one. I'm only on my second one after 40 years.
They are an indispensible tool- the best I have found- for removing the screws that hold many of the external hoseshoe magnets on various magnetos. For some reason, nothing I have found hardly works at all except the impact driver and it works awesome!
On the other hand........for your Fairbanks FMX magneto, I don't know if I would use it. Reason: those coil securing screws are pretty darn hard and they can fracture off half of the screwhead! Then you are really up against it because it is difficult to center drill the screw out and any wandering of the bit just goes off "towards the Joneses" and the soft aluminum will not help any to contain an errant bit.
I grind a screwdriver to fit perfect and tight, put the mag housing into a soft-jawed vice, and make liberal use of heat. Not so much as to hurt things but get it plenty hot and then try backing them out with whatever tool you've prepared.
Before any damage accrues the the screwhead, I stop and regroup. This may mean reheating and cooling with water sprayed from a spray bottle, or whatever but usually I repeat whatever I'm trying over and over until success is attained. I'm willing to retrace my steps, try something new or ???, but don't break the screwhead or you may be looking for a new housing.
When you're done re-assembling your mag, put a little anti-sieze on those screws, tighten them up, and then seal the screwheads with a dab of paint, hard-set Permatex, or whatever, but don't leave the screws dry and unselaed because you may want to get back in there in the future without having to fight them again.
Yeah, I really do like my Craftsman impact drivers but careful on those particular screws! Hope this little digression makes some sense and is of help. I've worked on quite a few of the FM-? magnetos but I've only had to drill out one of the screws and I vowed "never agin" !
Old 04-27-2008, 02:58:54 AM
BSTexas BSTexas is offline
This may not work for you, but here it is: I've used the impact screwdriver head and bit with a ratchet (sometimes with cheater bar) and had some good results using good old fashioned regular torque. You might try that first if there's any danger of cracking the screw on impact. It's even worked for me in cases where the impact failed. Just an idea. Good luck.
10' Steel Wheel Driver Bruce Flatmoe Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 119 01-19-2017 01:47:13 PM
Good place to buy engine carts Chris J Hit & Miss Gas Engine Discussion 13 11-29-2009 11:01:01 AM
Where is a good place to find blueprints to hit and miss engines? mack boyle Machine Shop and Tool Talk 3 01-13-2008 12:40:09 AM
Where to find Torque Driver for screws? Fred M. Machine Shop and Tool Talk 11 01-04-2008 07:53:00 PM
Where is a good place to look for an old engine neill06 Antique Engine Archives 10 10-16-2004 07:25:41 PM
