Twin City 27-44 Restoration Started
this thread has 168 replies and has been viewed 44775 times
Old 03-12-2010, 02:58:13 PM
Default Re: Twin City 27-44 Restoration Started
More progress,
I sent my clutch shaft to a machine shop about 15 months ago,...one of those deals where it collected dust while everything else came first
This put my resto efforts behind some, however, as you can see I now have a new clutch shaft with beveled pinion on it.
It is very well done and was treated for hardness so I can put this old road builder back to work without dropping teeth into the rear end case.
In an effort to benefit other collectors I want to re-run a bit of information from the start of this thread.
20-35's seem to be fine, but sometime after re-rating to 27-44 an unknown amount of these machines did not get this gear hardened correctly from the factory. I know this because I turned the entire US upside down looking for a replacement. I found six 27-44 rear ends left over from parting efforts. This shaft/gear was gone out of everyone of them. I have looked inside several others and found a couple more of them that do not look good. Be cautious over this fact if you are planning on buying one of these tractors! Pieces of the gear face separate and drop off. My tractor is mid-production, and I have no way of knowing just how many of these machines suffered from this unfortunate disorder
Access to this gear can happen in minutes by removing fuel tank and tank saddle. Then remove a small two-bolt shifting fork cover in the top of clutch housing. You may then look straight down into front of transmission at the beveled pinion gear. Good luck everyone!
I am elated to have this new part, as resto efforts can be on the move again
ID:	75277   Click image for larger version
ID:	75278   Click image for larger version
Name:	10th b-day 017.jpg
ID:	75279   Click image for larger version
Name:	10th b-day 018.jpg
Last edited by Tony Thompson; 03-12-2010 at 03:36:42 PM. Reason: forgot to tell you where to look (Bonk)
Old 03-12-2010, 05:04:12 PM
Phil Johnson's Avatar
Looks very good, Tony. They had to scrap more metal than they kept if that first pic was of the billet they started with!
I hope the smaller TC's are not afflicted with similar gear issues.
  #63
Old 03-12-2010, 09:33:09 PM
Phil,
There was a rather expensive pile of trim on the floor from that big high quality blank that I purchased to get this gear program off to a start.
The early baby twin cam did have a similar problem.
I will make a post on Phils thread , (TC found in old log barn)
That will detail this issue.
Old 03-13-2010, 10:35:59 AM
Tony B. Tony B. is offline
Looking good Tony!
Say do you happen to know what kind of material they made that out of and what they hardened it to?
Keep up the good work
TonyB.
The Following User Says Thank You to Tony B. For This Post:
  #65
Old 03-14-2010, 10:22:11 AM
Dave Preuhs Dave Preuhs is offline
Tony,
Lookin' good! Sometimes you gotta do what you gotta do to get the parts replaced or repaired, it don't pay to put back in a defective part when doing a total restoration job.
You better keep going, '11 will be here before you know it.
Dave
The Following User Says Thank You to Dave Preuhs For This Post:
  #66
Old 03-22-2010, 06:38:29 PM
That information was discussed with gear maker, but some time has passed and I do not remember the specs.
Reputable machine shops and the folks who run them know just what specs to work by and much of the work done these days is of better quality than it was years ago.
Sometime along the way the cast bearing carrier had a chunk broken out of the area that retains the felt grease seal on the outside and the thrust/bearing set on the inside.
I fitted a donor piece back in with my spray-transfer-powder-torch. Here are some before and after of the bearing carrier.
Name:	big tc clutch 001.jpg
ID:	75918   Click image for larger version
Name:	big tc clutch 002.jpg
ID:	75919   Click image for larger version
Name:	big tc clutch 003.jpg
ID:	75920   Click image for larger version
Name:	big tc clutch 004.jpg
The Following 8 Users Say Thank You to Tony Thompson For This Post:
  #67
Old 03-22-2010, 06:57:00 PM
The race for the old Hyatt flat roller is retained by a threaded set screw and a safety wire. I reloaded the carrier with all comonents and installed it to check running clearance.
To zero in on proper gear clearance quickly, I turned the assembly by hand and fed strips of paper through the gears. I added shims to the carrier-to-case gasket until the assembly turned smooth and was not cutting the paper anymore.
Final gear set was achieved with proper shims and the
"bloo goo" that we refer to as Dykem that revealed a gear contact path that really made my day
Name:	big tc clutch 005.jpg
ID:	75922   Click image for larger version
Name:	big tc clutch 006.jpg
ID:	75923   Click image for larger version
Name:	big tc clutch 009.jpg
The Following 7 Users Say Thank You to Tony Thompson For This Post:
  #68
Old 03-22-2010, 07:22:25 PM
Earlier in this thread complete restoration of the large, double Twin Disc clutch was detailed.
Now comes another problem area.
The huge, heavy clutch assembly slides in and out on the clutch shaft with only a snap ring to stop it from traveling the clutch pedal away and becoming intimate with the rear of flywheel.....not a real great design, however, by bolting engine in place with no clutch in the housing it becomes obvious that a quarter inch spacer can be placed in between the snap ring and back of flywheel to stop the over-travel if the snap ring ever blows of the end of shaft. I put one in because I do not trust the small ring to bear this kind of load (have seen more than one gone).
Second photo is birds eye view of completed clutch and engine short block bolted in place. Last photo shows the two bolt shifting fork cover that you can look under to see if your gear was as shot as mine was. Just pull off the tank and saddle to have a peek.
Name:	big tc clutch 011.jpg
ID:	75925   Click image for larger version
Name:	big tc clutch 012.jpg
ID:	75926   Click image for larger version
Name:	big tc clutch 013.jpg
The Following 10 Users Say Thank You to Tony Thompson For This Post:
  #69
Old 03-23-2010, 03:13:56 AM
mikepea
Hi Tony
Some excellent work done here, congratulations, how is the end thrust from the gear dealt with?
Best regards
Capone
Old 03-23-2010, 10:54:41 AM
Capone,
I did not show it, but a roller and race thrust bearing goes in the cast carrier first.
I may have been a bit skimpy on some of the complete assembly details, however, my main goal here is to inform people of the fact that many of these tractors suffer from a defective clutch shaft and where to look for the problem.
Also, if the rather inadequate snap ring lets go of the clutch shaft (it happens), and your clutch assembly over-travels until it strikes the back of the engine flywheel, you may run the risk of letting the throwout bearing collar fall out of the engagement fork.
Tony
Last edited by Tony Thompson; 03-23-2010 at 10:59:48 AM. Reason: gray haired & still cant spell !!!
Old 06-19-2010, 10:32:23 PM
Do not get to work on my tractor very often, but have made a bit of progress here and there.
The short block was set back into the tractor and it is time to start rebuilding and fitting all the external components on.
The engine in this tractor was trash, showing signs of accumulated moisture that pitted the oil pump to peices along with much of the rest of it.
For anyone needing oil pump parts for the big twin cams, many of them are the same on the baby twin cams. There are early and late versions but other than that I was able to get 17-28 pump parts to fit for my 27-44. The pump pressure regulator spring will flex under pressure and rub itself thin where it contacts the pump bore that it is installed in. These springs are available from dedicated hardware stores and must be replaced.
Second photo...here is the drive shaft and gear for the oil pump. At this point of assembly this stub shaft with gear on front has endplay. When you bolt the oil pump on, you must verify endplay again. If endplay is gone and pump gears are binding, then you need to add gaskets under front gear plate to set endplay, see third picture.Make sure to use soft copper sealing washers on the bolts that hold the oil pump to front gear case or they will leak oil.
Fourth photo shows top cap removed to afford access to a large slotted screw head with spring and check ball under it. with engine running, you can turn this plug up and down to increase or decrease your oil pressure setting. 20 lbs. is plenty.
Name:	TC oil pump 003.jpg
ID:	81298   Click image for larger version
Name:	TC oil pump 001.jpg
ID:	81299   Click image for larger version
Name:	TC oil pump 002.jpg
ID:	81300   Click image for larger version
Name:	TC oil pump 004.jpg
The Following 9 Users Say Thank You to Tony Thompson For This Post:
  #72
Old 06-19-2010, 10:45:33 PM
I also have had my magneto refurbished and test run by Todd Cory at Cory Engines in Delavan, Mn.
Oil pump, water pump and mag is installed and "shimed or aligned" so the multiple function drive shaft runs straight and quiet reducing wear at the couplers.
On the other side of engine the governor has been serviced and installed. All the large headstuds were cleaned and installed with antiseize.
Heads will be next!
Name:	Paige with new chicks 008.jpg
ID:	81302   Click image for larger version
Name:	Paige with new chicks 007.jpg
ID:	81303   Click image for larger version
Name:	27-44 TC 009.jpg
ID:	81304   Click image for larger version
Name:	27-44 TC 008.jpg
Old 06-20-2010, 10:03:39 PM
L Wilson L Wilson is offline
looking good!
Old 06-20-2010, 11:15:49 PM
Nice to see some more progress, Tony. I didn't know the oil pump parts were interchangeable on the two sizes of tractors.
Old 06-21-2010, 12:33:43 AM
Phil,
Twin City part numbers are cleverly set up to help with speedy identification if you know how they work.
12-20 and 17-28 engine casting numbers start with TW, chassis casting numbers start with TY.
20-35 and 27-44 engine casting numbers start with AE, chassis casting numbers start with AT.
The oil pump on an AE engine has TW part numbers casted on it, this tells you it is the same (12-20,17-28)pump on both engines.
21-32 numbers are FE and FT,
KT numbers are KE and KT,
If you memorize the numbers you can pick a Twin City part out of a pile and know by the two letter prefex that it is an engine or a chassis part and also know what model it is off
Of
The Following 3 Users Say Thank You to Tony Thompson For This Post:
  #76
Old 06-21-2010, 10:51:38 AM
Tony; I just rebuilt the oil pump on the 12-20 and machined a new shaft for the driven gear and remounted it back on the front housing where it is supposed to be. I had to machine over .010" off the front housing to remove the gear tracks from the oil pump gears. Is that early style die cast pump housing reliable? I know a lot of that early die-cast material gets very fragile over time.
Old 06-21-2010, 01:10:31 PM
Phil,
I do not understand the temperment and reasoning behind the use of die cast material that has also been refered to as pot metal or white metal.
The TC governor housings (not early 12-20 Pierce governor) were die cast as well. Many of them are cracked and crumbling away. Others look fine. The housing on my 20-35 is covered with cracks and have not touched it because I believed it would break to pieces when I tried to dissassemble it. I have found a used replacement that looks to be in sound usable condition.
In short, I have learned that some of these inferior castings desintegrate while others last for many years. If the casting in question is in decent condition, it should be fine for some time to come.
The later oil pumps are cast iron, (gee, I wonder why )
The governor housing on my current 27-44 resto is in perfect condition - maybe some of them were replaced with better quality parts in the forties or fifties
  #78
Old 06-21-2010, 10:31:02 PM
Time to report some specs on the heads for 20-35 and 27-44.
There is very little information circulating about the different components of these machines because original owners have passed on and very few of these tractors are actually getting restored. Most of them just set in a collection somewhere with their past remaining a mystery.
I have learned a great deal about thease tractors the hard way...hands on resto work, many hours studying original litterature and careful examination of everyone I ever ran into.
I have been told in the past that all the heads for these low production machines are all the same...Wrong!
Be very carefull if you are going to head swap a big twin cam. Even the parts book shows a high compression head and a low compression version, however, it gets more complicated than that.
The head numbers start with AE and are found on the top of head under the valve cover. there is a way to identify different heads from the outside of a complete engine without any dissassembly. I have a couple of photo's of the heads for my tractor that were just serviced at Todd Cory's shop in Delavan, Mn. My tractor has a set of low comp. heads on that are seldom seen. I assume that since it was a road builder, it was ordered this way to run many hours at a time on kerosene or disilate
In the last two pictures I am measuring the depth of the chamber and overall height of head casting from top to bottom.
Here is what I have learned.
AE 3A is a low comp. head with a huge chamber that is 2 1/2 inches deep. This head is 7 1/4 inches tall. It uses a smaller diameter valve stem than the other heads. I believe this to be a very early 20-35 head. In an attempt to calculate chamber volume and comp. ratio, I was stunned to realize that this head may only provide about 3 1/2 to 1.
AE 3G is a medium comp. head with chambers that are 2 1/4 inches deep and outside hight of 7 1/8 inches.
AE 203F is the high comp. head and is by far the most common one used on these tractors. The chamber is 2 inches deep and the hight is 6 7/8 inches tall.
As you can see the chambers are 1/4 inch apart from one another and outside casting hight is 1/8 inch apart from each other.
All of these heads actually produce fairly low compression and I have seen 1/4 in thick plates bolted to the top of pistons in an effort to get more power out of them. There was a few AE 203F's that had provisions cast in them to run dual plugs, but I have yet to see one that was drilled and tapped for all four plugs...may have been a factory plan that was never carried out
Later on after the merger, MM tooled up for and produced a two valve semi hemispherical head for this engine but it was only applied to 641 ci. stationary engines.
I had a very puzzeled 27-44 owner contact me claiming he had torn into his tractor and it had one four valve head on it and one two valve head on it. Apparently the only available replacement head for that tractor at the time of need was a late two valve power unit head
I had better get out to the shop and start making some head gaskets, good luck on all your projects everyone!
Name:	27-44 TC 003.jpg
ID:	81470   Click image for larger version
Name:	27-44 TC 004.jpg
ID:	81471   Click image for larger version
Name:	27-44 TC 006.jpg
ID:	81472   Click image for larger version
Name:	27-44 TC 007.jpg
  #79
Old 06-21-2010, 10:47:09 PM
Good Information, Tony. You've done a lot of work! I'll check heads on mine.
The Following User Says Thank You to Oilpulled For This Post:
  #80
Old 07-17-2010, 08:45:57 PM
Valvetrain report,
Most of these engines end up with badly worn top end components if they were used hard. This engine was designed in 1916 or 1917 and the valvetrain needed to be hand oiled through a set of small pipes/cups protruding through the hood on a regular basis to minimize wear.
In the past several of these machines were up-dated by ingeious owners that piped oil from the pressurised lower end gallery to the top of valve covers to avoid the regular hand oiling schedule. Oil had to be delivered to eight different sites atop the valve covers making a bit of an under hood plumbing nightmare.
Late in the 27-44 production run, the factory supplied a new rocker arm bracket and shafts to provide force feed lubrication to the top end. These new parts did a tidy job of oil delivery with only a tee and two short oil lines up top.
Many of the earlier tractors were fitted with this conversion and so was #250417 that is being restored here.
First photo shows assembly for one head, second one dissassembled, third and fourth pictures show early AE41B hand oil rocker stand and later AE41D recast with oil gallery in it.
Name:	27-44 valvetrain 001.jpg
ID:	83125   Click image for larger version
Name:	27-44 valvetrain 002.jpg
ID:	83126   Click image for larger version
Name:	27-44 valvetrain 003.jpg
ID:	83127   Click image for larger version
Name:	27-44 valvetrain 004.jpg
The Following 5 Users Say Thank You to Tony Thompson For This Post:
Twin City 40 Tom Cwach Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 11-16-2016 03:03:49 PM
Twin City 17-28 Jim Gordon Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 06-07-2008 07:25:42 PM
MM Twin City JTS DavidRaines Antique Farm Tractors 3 05-10-2008 11:02:19 AM
Twin City 17-28 Phil Johnson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 18 12-28-2007 12:03:49 PM
Twin City Kevin Roth Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 01-13-2005 07:54:14 PM
