Allis-Chalmers Model E - Modified?
this thread has 114 replies and has been viewed 35969 times
Old 05-31-2012, 10:26:35 PM
Charlie1925 Charlie1925 is offline
Default Re: Allis-Chalmers Model E - Modified?
Big Charlie is RUNNING! And Roger is pumped...have not seen him this excited in a long time. The video has some background noise from the lawnmower at the beginning but then you can really here Big Charlie purr. Lets us known what you think....
The Following 11 Users Say Thank You to Charlie1925 For This Post:
Old 05-31-2012, 11:14:10 PM
Nice runner!.......
Where does the top end get its oil from?
  #43
Old 06-01-2012, 12:46:07 AM
Phil Johnson's Avatar
Sweet!!! The ol' girl sure runs nice. Congratulations!1
The Following 2 Users Say Thank You to Phil Johnson For This Post:
  #44
Old 06-01-2012, 12:56:25 AM
Paul Roidt Paul Roidt is offline
Sounds Great. My Dream tractor! Looks a little dry up top, as Craig eluded. Nice valve springs.
The Following 2 Users Say Thank You to Paul Roidt For This Post:
  #45
Old 06-01-2012, 03:22:34 AM
Brothers Clemens's Avatar
Charlie,
Its great and running fine with the governor that can give noise like an lion.
Nuts about these AC’s
Like you shop also very much.
Coult be full with a lot of treasuries in hidding.
Wish we coult have our shops in Holland that way.
Thanks for posting.
Chris
The Following 2 Users Say Thank You to Brothers Clemens For This Post:
  #46
Old 06-01-2012, 04:47:27 AM
Richard Sturdy
Sounds very nice indeed and you are a lucky man to have such a treasure! I am hoping that the owner of the only European example will be bringing it to the YVA show at Newby Hall in Yorkshire next week.
Tricky Dickie
The Following 2 Users Say Thank You to For This Post:
  #47
Old 06-01-2012, 12:06:42 PM
Sounds great! He sure doesn't look too excitable in the video though!
The Following 2 Users Say Thank You to Brasherman For This Post:
  #48
Old 06-01-2012, 03:23:25 PM
Old Scrambler Old Scrambler is offline
Craig..............the top end has an oil feed that keeps the 'cups' full on the rocker-bar. It drains down the push-rod tubes. Roger plans to get the leaky radiator repaired, add a little more paint, and get Big Charlie ready for the July GOTO in Ohio.
Charlie is a little brother to the Model E but Big Charlie got his name because when he was rebuilt in 1946-47 more than 20-thou was shaved from the head and we think 1st-over pistons were installed. He always had good compression.........and now a few more thou was shaved to plane the head and the tops of the cylinders.
---------- Post added at 02:17 PM ---------- Previous post was at 02:12 PM ----------
Hello Chris..........Dennis in Wisconsin..........talking about my brother Roger in Georgia where Big Charlie has come to live.
The rocker 'cups' have a lot of oil to splash around.
Roger's shop is mostly full of semi-tractors but he has been familiar with Big Charlie since he was 7 or 8 years old.
---------- Post added at 02:23 PM ---------- Previous post was at 02:17 PM ----------
Brasherman...........Big Charlie and Roger are a LOT camera shy! You had best have a chair in the shade and a beverage handy though, if you see Roger at a show and ask him anything about Big Charlie.
The Following 3 Users Say Thank You to Old Scrambler For This Post:
  #49
Old 06-01-2012, 09:47:28 PM
Brian Ahart's Avatar
Brian Ahart Brian Ahart is offline
The old L sounds great! Maybe one day I'll have a chance to chat with you guys at a show and see Big Charlie in person. Don't be camera shy. Hope to see more pics and videos in the future to keep us salivating.
The Following User Says Thank You to Brian Ahart For This Post:
  #50
Old 06-01-2012, 10:22:45 PM
A little more about the oil system............This Midwest motor has a drilled crankshaft to feed the bearings..........a baffle-plate is mounted just above the oil level in the pan and directs oil "mist" that splashes from the crank upward through the push-rod tubes.......thats the feed to the head that has a vent (notice the multiple vent-holes on the right side in the video) so the mist has no back pressure. When there is too much oil in the head it simply drains back down the tubes. Reference to Post #35.
The motor block has two 7/16ths drain plugs between the push-rod tubes that are meant to be drained at the same time as the crankcase. Roger said that when he was checking to make sure everything was getting oil, he pulled one of the inspection plates and oil 'shot' about 10-feet across the shop floor from the crank at idle-speed.
The original gas tank has surface rust inside but does not leak. Roger cleaned it out with a vacuum but has not removed the tank. He plans to do a little more frame painting and will install the air-cleaner pipe with a filter inside of the water-bath before he take Big Charlie to the Plain City GOTO.
The Following 2 Users Say Thank You to Old Scrambler For This Post:
  #51
Old 07-20-2013, 10:47:35 PM
It is nice to see Big Charlie getting some sun!
Photo courtesy of Pat in CIL on the allischalmers.com forum.
The Following 4 Users Say Thank You to Brian Ahart For This Post:
  #52
Old 08-28-2013, 02:42:23 AM
Thanks, Picture was taken at Dale Haymakers last show a few weeks back
The Following 2 Users Say Thank You to Charlie1925 For This Post:
  #53
Old 01-01-2014, 03:37:34 AM
Happy new year to all of the great people on this network, May good things come to all of you. Hope to see some of you at the shows.
The Following 4 Users Say Thank You to Charlie1925 For This Post:
  #54
Old 07-22-2014, 10:01:37 AM
Fellow Stakers,Big Allis Chalmers show this week end July 25-27 2014.The Orange Spectacular at Hutchison,Minn. Any color shit or cap allowed, But only Allis Chalmers tractors. 100th. Anniversary of the Orange /Green tractors. Big Charlie will be there. He's a 1925 model "L" 12-25 See you all Roger Weinhold Aka Charlie 1925
The Following User Says Thank You to Charlie1925 For This Post:
  #55
Old 07-26-2014, 10:20:50 PM
RFreshour RFreshour is offline
Roger, Are you still coming to LaPorte ?
The Following User Says Thank You to RFreshour For This Post:
  #56
Old 07-28-2014, 12:59:50 PM
I had the pleasure of speaking with Roger at the Orange Spectacular. It was great to meet Roger in person and learn the family history of this rare A-C tractor, and the journey back to running condition. I also got to chat with his sister Barb and brother-in-law on Friday. This is one of the models that most A-C nuts like me can only dream of owning.
Roger, thanks for taking time to chat and allowing my girls to climb all over the tractor and get their pictures taken!
Brian Ahart
ID:	201468   Click image for larger version
The Following 2 Users Say Thank You to Brian Ahart For This Post:
  #57
Old 07-30-2014, 09:55:44 PM
Yes, Roger will be there............He stopped at my house on his way from the SPECTACULAR to Freeport. Your next.......
Old 07-31-2014, 12:00:18 AM
99 SD PSD 99 SD PSD is offline
Smile Re: Allis-Chalmers Model E - Modified?
Absolutely AWESOME. NO ONE CAN APPRECIATE THIS OLD TRACTOR MORE THAN BOTH OF YOU!!! THANKS FOR SHARING. I'm in the process on tracking down some of Dad's old tractors myself. So far got 2 of them. I can appreciate the joy this must bring to your family! Now if I can only figure out where Dad's old Allis 25-40 that sold late at the Erdle sale got to?
The Following User Says Thank You to 99 SD PSD For This Post:
  #59
Old 09-02-2014, 01:05:47 AM
Brain Post the pictures of your girls, I do allow a lot of kids on Big Charlie. We got to Freeport, Ill. for that show, It was to honor the people that started the GOTO and the Old Allis News. We had a good time there. Dave Harington of Nebraska was there with his duplex tractor, witch is two 6-12's put togather, back to back. Then on to LaPorte, Ind. for there GOTO and Rumely show. Big show, over 700 AC tractors and equipment there. We went home to Ga. for 2 weeks, now to Union Grove, Wis. with a little side trip to Milwaukee for the AC plant thing and road trip.
Then back home for 5 or 6 shows in Ga. Fla.& Ala. Roger Weinhold AKA Charlie 1925
Old 10-04-2014, 02:39:59 PM
Roger, how was the Union Grove show? I'm surprised no one has posted pictures on the A-C forum yet.
Allis-Chalmers Model U Ben Dixon Antique Farm Tractors 21 07-02-2014 07:50:44 PM
Allis-Chalmers Model U at the Tractor Pull Wayne Hansen Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 11-28-2008 08:34:45 PM
Allis Chalmers Model B ??? GregSenn Antique Farm Tractors 4 12-19-2005 09:39:33 PM
Allis Chalmers Drew Antique Engine Archives 1 06-16-2004 08:37:52 PM
Allis Chalmers I.B. Aaron Antique Engine Archives 3 02-24-2001 12:00:33 AM
