Is this tool for mills?
this thread has 9 replies and has been viewed 2348 times
Old 01-18-2010, 10:30:15 PM
Ray Cardoza's Avatar
Default Is this tool for mills?
http://entertainment.webshots.com/ph...03158688JrKzLR
3 flutes and threaded on one end. made by clevland twist drill co
Old 01-18-2010, 11:58:59 PM
NAMPeters
Default Re: Is this tool for mills?
Picture a bit fuzzy and the pop-up and ad a PITA. With that said it looks like a coolant feed through cutter for a CNC machine.
Old 01-19-2010, 02:37:07 AM
Wayne Price Wayne Price is offline
Maybe a special reamer, a profile cutter.
Old 01-19-2010, 09:47:11 AM
K D Redd K D Redd is offline
Looks to me as if it is a drill and countersink in one tool. Not been around CNC units but I did not think thay used screw in tooling.
Kent
Old 01-19-2010, 10:10:07 AM
Culy's Avatar
Culy Culy is offline
This looks alot like the profiling tooling that a company I worked for many moons ago used. Only on a different scale. The company made aluminum manifolds for Navistars air conditioning systems. They would predrill the billit and then use a profiling cutter such as this to get the correct sized hole and inside dia. profile for valving and ports. Ours were made with a coolant port through the cutter. They were an expendable tool, as we would dispose of them frequently since they would wear and be out of spec. for the ISO standards.
Brian
"The only limit to fabrication is....IMAGINATION"
Old 01-19-2010, 11:30:44 AM
rustyironengine rustyironengine is offline
These cutters are for drilling, reaming and countersinking in one operation. they are usually used in the aircraft industry with a depth stop cage to control the Countersink depth.
Cutter and Cage can be seen here:-
http://www.cooperpowertools.com/bran...ters/index.cfm
Hope this helps
Regards
Andy
Old 01-19-2010, 12:11:32 PM
ronm ronm is offline
that's no lie....
Old 01-19-2010, 04:42:04 PM
sorry about the pop up and ad's i cant do much about them. thanks for the info guys
Old 01-19-2010, 10:59:47 PM
RE: pop-ups
I have IE8 with pop-up blocking enabled.
I got ONE pop-up......ditto in Opera.......
Old 01-19-2010, 11:53:22 PM
OTTO-Sawyer's Avatar
Other than having the threaded end for changing cutter heads on the shank, it looks like a counterbore tool made for a specific part. Use them all the time on screw machines and CNC lathes. The ones I've used were all straight shank (3/4inch or 1 inch dia.) instead of having the small threaded end.
Some are purchased ready made (special order), and some are simply made 'in-house' in the tool room by modifying an end mill, drill, or reamer, depending on how big of steps are needed between the diameters.
Rough drill / bore the holes with each size drill leaving .010-.030 on depth(s) and diameter(s), and then run that special tool in to blend everything together to hold all the depths & diameters without having any runout between them.
With all the hole sizes drilled individually, any or all of the drills can wander off center. These tools true everything up and finish the part, plus put in radii, fillets, and chamfers.
Grist Mills Mike F Farm Antiques and Collectibles 4 11-07-2010 01:24:51 PM
Grist mills Don Buchanan Hit & Miss Gas Engine Discussion 29 11-20-2008 01:54:41 AM
Speaking of mills... DanR Farm Antiques and Collectibles 5 02-15-2008 01:14:41 AM
Challenge Feed Mills Steve Barr Farm Antiques and Collectibles 4 11-28-2007 01:20:39 PM
threshing mills todd michel Steam Stationary Engines, Traction Engines 1 03-29-2006 10:06:51 PM
