Official Minneapolis Threshing Machine Company Thread
this thread has 92 replies and has been viewed 22822 times
Old 02-13-2010, 02:55:26 PM
A Martinson's Avatar
A Martinson A Martinson is offline
Default
Use this thread as the central location for discussion on the subtle differences on MTMC tractors of different years and any other MTMC stuff.
22-44
20-40
Single speed 35-70
40-80
ID:	126429   Click image for larger version
ID:	126430   Click image for larger version
ID:	126431   Click image for larger version
Old 02-13-2010, 03:09:17 PM
Default
This tractor is referred to only as the "Farm Motor" in literatureI have, but it later evolved into the 25-50 model. If someone has a scan of the 25-50 that they could post, that would be great.
20-40 Engine
Early 40-80 Engine
Late 40-80/35-70 Engine
ID:	126436   Click image for larger version
ID:	126437   Click image for larger version
ID:	126438   Click image for larger version
Name:	Minneapolis Farm Motor 1b.jpg
The Following 11 Users Say Thank You to A Martinson For This Post:
Old 02-13-2010, 03:26:21 PM
AultmanTaylor AultmanTaylor is offline
Default Re: Official Minneapolis Threshing Machine Company Thread
Hi
Very nice pictures!
One thing: are you sure you didn't mix up the 40-80 and 35-70?
The reinforcement going to the front axle in your pictures on the 35-70 is flat and on the 40-80 it's down like most of the MTM's.
We have a 35-70 which originally was a 40-80 which has the reinforcement flat. Since it is broken on ours I think that it were the earlier ones that had it flat.
regards
Old 02-13-2010, 03:31:44 PM
I'm sure I didn't mix them up, but that doesn't mean the images are 100% correct in the first place.
The reinforcement looks the same on our 40-80, which was bought new in 1918, #1299 as in the drawing.
http://oldironzone.com/prairietracto...eapolis_40-80/
Here are some more pictures of our 40-80
The Following User Says Thank You to A Martinson For This Post:
Old 02-13-2010, 04:39:50 PM
hi
It's just strange that all the 35-70's and all the 40-80's we've seen have the reinforcement like that. Execpt for the 35-70's that are re-rated 40-80's with an R in front of the serial number.
Old 02-13-2010, 04:51:53 PM
They may have only used that type of reinforcement for a short time as I have also seen remanufactured 40-80s with the angled reinforcement.
Old 02-13-2010, 07:38:12 PM
It definitely wasn't good construction. Ours is broken.
I think that the first ones were like ours because a 25-50 has it flat as well. Maybe the ad of the 35-70 is a remanufactured one
Old 02-13-2010, 07:53:35 PM
At Jeff Jacobsen's website http://tractorhorn.tripod.com/ there is an even earlier one that also has the diagonal bracing.
This is the tractor that turned into the 25-50, and it also has diagonal bracing.
What is your tractors SN?
Old 02-14-2010, 06:45:12 PM
Mike Harmeling Mike Harmeling is offline
Here's a representative of the 30-50/39-57.
Mike
About the only change in them seems to be the rating on the serial number plate after the Nebraska tests.
The Following User Says Thank You to Mike Harmeling For This Post:
Old 02-14-2010, 07:57:53 PM
The number is R1637. It has the double ignition, 2 spark plugs per cyl and a closed governer.
Old 02-14-2010, 08:05:44 PM
Where is the governor located? In the cab, or on the engine?
Your S/N is 10 before the Nebraska tractor, #1647. Interesting that it was remanufactured.
Old 02-14-2010, 09:03:46 PM
The governer is on top of the engine. Never saw one with it inside te cab
I think the moment they were remanufactured they got a new number?
Old 02-14-2010, 09:09:52 PM
Ours has the governor in the cab, directly above the carburetor.
As far as I know, the R was just stamped on the existing tag. I know of one with SN R612, which means it would have to be the original S/N as it has OHVs.
Old 02-15-2010, 02:30:00 PM
R is cast on the plate, as is the number. The plate with the number is a loose piece of the plate with the type on it. Kinda like the ones on the 17-30's
Old 02-16-2010, 04:58:12 PM
smtwins smtwins is offline
Photo Re: Official Minneapolis Threshing Machine Company Thread
Here is a picture of 35-70 R 1041 Serial Tag. This tractor used to be in the Ohio Area years ago. Mr. Stucky I believe. It came from the Twin City area when he bought it. Would be nice to see if someone had pictures of it in its work clothes.
Name:	36-70 minnie 001.JPG
ID:	73561   Click image for larger version
Name:	36-70 minnie 003.JPG
The Following 3 Users Say Thank You to smtwins For This Post:
Old 02-16-2010, 05:35:00 PM
Here is the in cab governor
The Following 4 Users Say Thank You to A Martinson For This Post:
Old 02-16-2010, 09:50:17 PM
I see that Pickering does not have the automatic shut down feature that most Pickerings of that type do.
That's one tractor you don't walk away from when it's running.......
Old 02-16-2010, 11:01:28 PM
Dear Mr. Martinson!
This is an excellent thread. Thanks for all the fine data you are placing on Smokstak! I suppose there will be a Farquhar gas/oil tractor thread in the near future?
I still say you need to write a book! It would be a dandy!
And Craig? Do you think the big, ol' Minnie could get her wheels off the ground if that Pickering should happen to run away?
All the best,
G.
Old 02-17-2010, 03:49:52 PM
Casesteamer Casesteamer is offline
If you look closely, it apears all the straight angle brackets are on the road tractors where the motor ran counter-Clockwise or up if you were standing in front of it.
Also while researching in the Minnesota History Museum. I found a parts book that said tractors prior to 1917 had a chain driven water pump. All tractors after this had a belt driven water pump. Was probably also the same time the radiator was flipped around.
The Following User Says Thank You to Casesteamer For This Post:
Old 02-17-2010, 04:00:41 PM
All the best,
G.
Nah.......being a 4 banger I think it would just fly apart all at once.......
Minneapolis Threshing Machine Co. Serial Numbers John Rhodes Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 07-28-2007 12:02:01 AM
A MINNEAPOLIS thread David Parfitt Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 05-16-2006 01:05:27 PM
Threshing Machine Rumely7106 Steam Stationary Engines, Traction Engines 2 05-04-2005 08:29:26 PM
The Good Machine Company / American Roads Machine Jeff Smith Hit & Miss Gas Engine Discussion 0 04-15-2005 11:10:28 AM
Advance Threshing Machine Thresherman Steam Stationary Engines, Traction Engines 0 11-16-2004 10:11:55 PM
