Gas Tank Cleaning
this thread has 5 replies and has been viewed 2789 times
Old 06-13-2010, 06:05:36 PM
peerless peerless is offline
Default Gas Tank Cleaning
Hello, what is the best thing to use to clean very gummed up tank. The tank is off a 3horse Bullseye engine .Thanks
Old 06-13-2010, 06:47:16 PM
Ray Medford Ray Medford is offline
Default Re: Gas Tank Cleaning
I have found acetone to be an effective solvent for old gasoline. Be sure to use outside with good safety procedures.
Old 06-13-2010, 06:54:08 PM
Arlie Levy Arlie Levy is offline
Try stick the sand blaster nozzle in the filler hole and that will get most of it.
Old 06-13-2010, 07:10:18 PM
John in Maryland's Avatar
John in Maryland John in Maryland is offline
I've had good luck with full strength Castrol Superclean and roofing nails or small pebbles.
J.I.M.
The Following User Says Thank You to John in Maryland For This Post:
Old 06-13-2010, 10:24:11 PM
Vic Neff Vic Neff is offline
Hi,
I've tried just about everything, and what I found "really works" great is "Spray Nine" It's Been great for me on gummed up tanks and check valves. Try it you might like it!
Old 06-14-2010, 11:33:23 AM
Robert Stevens Robert Stevens is offline
If it is gummed up with old gasoline varnish and goo, what works real good for me is alcohol (rubbing, methanol, Heet). Pour in, slosh it around and let it sit (an occasional shake doesn't hurt now and again) and then after 24 hours, pour the haz-mat out :-)
Bob
Gas tank cleaning. KeithW Hit & Miss Gas Engine Discussion 2 11-22-2005 02:57:49 PM
Fuel Tank Cleaning Mike Inglis Antique Engine Archives 6 07-03-2004 07:18:45 AM
tank cleaning Jim Hilgartner Antique Engine Archives 4 01-03-2004 12:24:50 AM
cleaning gas tank Mark C. Flewelling Antique Engine Archives 32 01-05-2003 01:56:13 AM
Cleaning out a gas tank Hal Davis Antique Engine Archives 6 06-26-2002 10:20:01 PM
