New purchase 20-40 Case
this thread has 156 replies and has been viewed 30850 times
Old 11-04-2010, 09:57:54 PM
Default Re: New purchase 20-40 Case
60!
Marilee certainly knows her stuff when it comes to restoring tractors. Congratulate her for me on her fine work. Oh! you did ok too I guess.
G.
Old 11-04-2010, 09:59:32 PM
60case's Avatar
60case 60case is offline
Oops forgot the clutch
Graduated from school of hard knox
The Following 2 Users Say Thank You to 60case For This Post:
  #63
Old 11-04-2010, 10:02:44 PM
60case's Avatar
Originally Posted by G Willikers View Post
60!
ill mention that to her
Old 11-05-2010, 07:51:28 PM
Grant McEwan
Looks Good!!!! Looks like you will posting pictures of a 20-40 driving down the street come this spring. Too bad it will be short the cab?? Grant
  #65
Old 11-05-2010, 08:26:12 PM
OTTO-Sawyer's Avatar
Cab or No Cab... That's a heck of a lot of progress in 2 1/2 months time.
The Following 2 Users Say Thank You to OTTO-Sawyer For This Post:
  #66
Old 11-05-2010, 09:21:28 PM
Grant McEwan
Yes you got that right!!!! It is coming together alot faster then a case steam engine or two?? Maybe next winter steam? It will be great to see the 20-40 run down the field pulling the old 6 bottom jd plow!!!! Grant
The Following 2 Users Say Thank You to For This Post:
  #67
Old 11-05-2010, 11:02:54 PM
Grant,
I don't know why you are always making so much fun of ol' 60? Notice the beverage bottle in the clutch picture above - he must have found that along the road and picked it up just to be environmentally helpful?
All kidding aside though, congratulations all around on the work being done on the old Case. It is certainly going to be a fine tractor and something to be proud of!
All the best,
To my friends in the West!
G.
  #68
Old 11-05-2010, 11:09:24 PM
Rich Wood Rich Wood is offline
uhoh: Notice the beverage bottle in the clutch picture above - he must have found that along the road and picked it up just to be environmentally helpful?
G.
That's some fancy IMPORTED beer ya got there, i'd stick with the local stuff if i was you though
The Following User Says Thank You to Rich Wood For This Post:
  #69
Old 11-06-2010, 09:12:34 AM
60case's Avatar
its not inported , but its good ,things are moving along weather bin just great here
thanks for the kind words
The Following User Says Thank You to 60case For This Post:
  #70
Old 11-07-2010, 01:34:54 PM
60case's Avatar
Just thikin here ? but can someone tell me what the valve tappet clearence should be
Old 11-07-2010, 05:02:40 PM
Ol' 60,
Seem to recall setting the clearance on my 20-40 Eagle about .015 (hot). You could probably open up even further if you plan on working it harder. I'll try and remember to check tomorrow.
Good luck,
G.
  #72
Old 11-08-2010, 04:21:02 PM
Ol' 60
Found in the ol' Eagle operator's book - 1/64 (.015) clearance in the Model H book and 1/32 (.031) in the older, Model F book!
Have fun lad! Say hi for me to your apprentice!
G.
Old 11-08-2010, 04:25:29 PM
60case's Avatar
Thanks uncle G
I dont know if case made book for a 20-40 but thats a good place to start . You are lucky to have a book for reference. Thanks for now
Old 11-08-2010, 06:45:51 PM
I'd be more concerned with the "valve open" or "valve close" marks on the flywheel than the clearances.
You can throw off the valve timing significantly going only by rocker clearances.
Old 11-08-2010, 07:15:19 PM
Glenn Gieszler Glenn Gieszler is offline
Inlet opens on center
Inlet closes 30 degrees past center
Exhaust opens 35 1/2 degrees before center
Exhaust closes 20 1/2 degrees past center
adjust push rods to .005 of an inch when cold
Old 11-09-2010, 09:01:43 AM
60case's Avatar
Ill look on the fly wheel for the marks ,not sure if they have any. .005 seems a little tight but what do i know,Glen where did you get this info?
Old 11-09-2010, 09:28:03 PM
From a 20 40 manual you can get one from richard tworek
Or jensales
The Following User Says Thank You to Glenn Gieszler For This Post:
  #78
Old 11-09-2010, 11:05:00 PM
It's not going to happen both ways. With valve seat, rocker arm and pushrod wear it will be either one or the other.
You'll be way ahead of the game if you adjust the valves by the flywheel marks regardless of what clearence you happen to wind up with.
Five thousandths has to be a typo.......
  #79
Old 11-10-2010, 09:28:31 AM
60case's Avatar
Thanks to all. I will look for the marks and track down a book
Old 11-14-2010, 02:29:18 PM
Grant told me about this:
http://www.smokstak.com/forum/showth...499#post579499
Who knew he would make it this far?
The Following 2 Users Say Thank You to G Willikers For This Post:
6.0 CCKB purchase ? enzo86 Onan Generators 16 04-09-2009 10:13:55 PM
New purchase - a 1928 25-45 model T crossmotor Case Alltractorman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 09-08-2008 08:22:54 AM
My new purchase... please help jaw123 Hit & Miss Gas Engine Discussion 5 03-31-2008 08:05:29 AM
New Purchase Brian Dykstra Farm Antiques and Collectibles 4 10-04-2006 11:38:02 PM
novo purchase wayne thomas Antique Engine Archives 2 04-29-2003 07:46:37 PM
