Ideal Lawnmower Engine
this thread has 2 replies and has been viewed 1812 times
Old 07-28-2003, 07:13:44 PM
Benny Mckheean in NC
Default Ideal Lawnmower Engine
I just purchased a Ideal Lawnmower engine and I have a few questions about the mixer and crankcover.It is the old style engine with 12 1/2inch flywheels and the rounded crank cover.My question is do you remove the two screws that hold the crank cover on and fill the bottom with oil or just oil the main ever so often?It has two grease cups for the outer crank.Is the mixer supposed to have a choke.Any pictures of one would be helpful.See the link of the engine.Thanks for any help. Benny in NC
http://www.webphotos.com/list_photos...smi=1&a=116461
Old 07-29-2003, 08:30:42 AM
Bruce Wambach
Default Re: Ideal Lawnmower Engine
Benny,
The crank cover needs to be removed and the case filled with oil so that crank barely skims the surface of the oil. This is a splash system and too much oil will cause excess oil to splash out as the cover is not a perfect seal.
Regarding your second question about the mixer, my Ideal is equipped with a Lunkenheimer mixer, that has only a needle valved and a spring operated compensating valve, there is no choke. To ensure there is gas at the mixer, hold the compensating valve up until gas begins to leak from the mixer intake. Hope this helps.
Bruce in PA
Old 07-29-2003, 08:53:36 AM
Bruce,There is no needle spring on my mixer,I think it is a homemade outfit.Can you send me a closeup picture of one?Thanks for the reply.Benny
Ideal Model R Lawnmower Engine Getter-Done Hit & Miss Gas Engine Discussion 8 02-22-2018 12:02:53 AM
Ideal lawnmower engine. Billy Purves Hit & Miss Gas Engine Discussion 1 02-05-2015 06:10:14 PM
Ideal lawnmower engine video Ray Cardoza YouTube Old Iron Videos 0 01-22-2009 02:03:15 AM
Slowing down an Ideal lawnmower engine Ray Cardoza Hit & Miss Gas Engine Discussion 15 07-23-2008 01:39:17 PM
Ideal aircooled lawnmower engine paint code help? Jordan Hit & Miss Gas Engine Discussion 1 05-13-2008 05:54:52 PM
