1867 Otto Langen SN 1 Where is it ?
this thread has 82 replies and has been viewed 23262 times
Old 06-03-2008, 04:56:56 PM
Marcel P's Avatar
Marcel P Marcel P is offline
Default Re: 1867 Otto Langen SN 1 Where is it ?
Originally Posted by Wayne Grenning View Post
Another one that was in the vaults. I heard years ago, such a gizmo existed but always thought it strange that they would go through all of the effort for 4 HP. ( especially when their single cylinder product line included engines much larger) Possibly two cylinders were used for very constant speed regulation - dynamo service?? This engine has spur & bevel gears, single sideshaft, vertical governor ( unusual for Deutz) and variable cutoff speed control. Anyone out there know why they did this for such a small HP? It is basically (2) 2 HP slide valve engines morphed together. What an amazing machine ! - Wayne
Hi Wayne
Many thanks for posting these pictures! It is strange indeed that they built a 4 HP two-cylinder, but as you say, dynamo service would have been the main reason. Besides of that, it was perhaps also the 'prestige' factor? The vertical upright governor is in my opinion more out of necessity, as a hanging governor would not be accessible? Also strange is, that most of the bigger (and later) 2-cylinder had two sideshafts, although the design with the central shaft seems more revolutionary to me.
So this makes 3 two-cylinder slide valves known to me, do you know of any more?
Best regards
Marcel
Old 06-04-2008, 12:36:26 PM
Wayne Grenning's Avatar
Wayne Grenning Wayne Grenning is offline
Images: 72
Marcel,
Agreed, it must have been designed for dynamo operation. The engine is serial number 14743. They have a display board near the engine that states it was made in 1880, but am sure it is incorrect. By the serial number I am guessing much closer to 1889 - 1890.
To answer your question, I am only aware of the three twin slide valve Otto - patent engines ( this one and the two 25 HP engines). I have seen engravings of Crossley and American Ottos twins but am not aware of any in existence today. - Wayne
Old 06-04-2008, 12:38:28 PM
Images: 72
Otto & Langen Bill Hazzard Hit & Miss Gas Engine Discussion 75 09-30-2017 10:04:21 PM
Otto & Langen gasengineman43 Hit & Miss Gas Engine Discussion 2 02-15-2016 12:38:22 AM
1867 Otto Langen engine antiquecarman Hit & Miss Gas Engine Discussion 15 02-16-2010 11:43:15 AM
Otto-langen James L Johnson Hit & Miss Gas Engine Discussion 27 03-21-2008 10:01:05 PM
Otto Langen Patrick M Livingstone Antique Engine Archives 0 10-06-2001 09:32:14 AM
