1893 Dayton Serial #3 Outside for 101 Years
this thread has 123 replies and has been viewed 28685 times
Old 02-14-2012, 12:15:03 PM
BuckeyeMan BuckeyeMan is offline
Default Re: 1893 Dayton Serial#3 Outside for 101 Years
Originally Posted by Culy View Post
Dave I've got a "?" not being familiar with Daytons. What is the third cam lobe for? What is its funtion? Just curious.
Brian
Brian, the one in the center is for the Ignitor, and the two outer one's, intake and exhaust. The 4th rod running up to the side of the valve box, is for the fuel valve....
Andrew, the wood spokes are what is left of a pulley.......
The Following 2 Users Say Thank You to BuckeyeMan For This Post:
Old 02-15-2012, 03:12:15 AM
After the engine was completely apart, the first thing that I needed to do was find a good heavy cart to mount the engine back on. I'm not big on carts, but it came on one so it needed to go back on one. I started making some calls to a few guys that deal in these thing and Larry out in Neb. said he had maybe what I was looking for. He sent me photos of about 6 different one to consider. Dad looked at all the photos and we made our decision and Larry said he could bring to Portland swap. It was not much to look at, but it was something to start with. One wheel was bent out of line about 8" and rusted solid to the axle, the 5th wheel was also a rusted mess.
The photos below are what I started with........DH
ID:	128876   Click image for larger version
ID:	128877   Click image for larger version
ID:	128878   Click image for larger version
The Following 7 Users Say Thank You to BuckeyeMan For This Post:
  #23
Old 02-15-2012, 03:30:04 AM
The engine was originally on 9X9 timbers, so off to the saw mill in early spring so they could start to dry a little.
The wheels where taken to a local sandblaster (I did not want to spend 3 days doing all those spokes) he had the job done in a day and primed them the next. I did all the rest of the parts while he did the wheels.
I spent about 3 days with a ruler, paper and pencil trying to decide just how I wanted to put this all together. I needed room for the water pump, the pump drive, and water tank. This is what I came up with................DH
Name:	Klein & Dayton 013.jpg
ID:	128880   Click image for larger version
Name:	Klein & Dayton 015.jpg
Old 02-15-2012, 08:17:46 AM
LCJudge LCJudge is offline
Dave, I think your cart is an original Root & Vandervoort truck. The Dayton will look nice on it.
Tommy Turner
The Following 3 Users Say Thank You to LCJudge For This Post:
  #25
Old 02-15-2012, 09:08:44 AM
Bill Hazzard Bill Hazzard is online now
Dave,
Those carts were also used for side shaft Witte engines.
The Following 4 Users Say Thank You to Bill Hazzard For This Post:
  #26
Old 02-15-2012, 10:44:43 AM
Thanks Tommy and Bill. Larry told me, he thought it was an old Witte cart, and then when Jeff Wahl posted the photos of that 12Hp R/V he got here some time back I noticed it was also the same cart.
The Following User Says Thank You to BuckeyeMan For This Post:
  #27
Old 02-15-2012, 11:40:56 AM
Jeff Wahl's Avatar
Jeff Wahl Jeff Wahl is offline
Dave, Nice looking cart! I recommend hanging onto the original rails. They are nice I-beams, which you don't see too often, and I don't believe they make that size anymore. Maybe someone will need them?
The Following User Says Thank You to Jeff Wahl For This Post:
  #28
Old 02-15-2012, 06:34:52 PM
Mark Thompson's Avatar
Mark Thompson Mark Thompson is offline
Email Not Working
Images: 75
Dave,
Are you going to try and use the original tallow pot to lubricate the cylinder? Or use another lubricating system?
-Mark
Name:	Johns engines 2 025.jpg
The Following 3 Users Say Thank You to Mark Thompson For This Post:
  #29
Old 02-16-2012, 02:54:36 AM
Yes Mark, This will be used, as it belongs on the and it should stay on. For those of you that have never seen an oiler like this, it was attached to the engine at the water coming out of the engine so that the worm water of the cylinder kept the oil worm. Don't quite know why they needed to do it this way, but that's the way it was made...........DH
ID:	128999   Click image for larger version
The Following 11 Users Say Thank You to BuckeyeMan For This Post:
  #30
Old 02-16-2012, 04:01:51 PM
After the engine was completely disassemble, all the parts where inspected to see what work was going to need be done and what might take the longest to get done. The wheels where taken to Kramer's machine shop in Eaton Oh. to have the rimes turned to remove all the pitting. This work was done on there Bullard, and they came out real nice. All the large parts where sand blasted and Primed and Painted, this was all done last summer.
This is where I'm at up this point, as fare as getting it back together.
I'v spent about the last 4 weeks in the shop making all new nuts, bolts, pines, sleeves, screws, more bolts, and machining up all the rest of the parts that where rust pitted real bad. The head was taken to a local machine shop and used there C/C lathe to clean up the head, and I spent a day at DeBolt machine shop cutting a new cam gear on his 1950 Fellows gear shaper. I'll get more on here later...............DH
Name:	Klein & Dayton 003.jpg
ID:	129032   Click image for larger version
Name:	Klein & Dayton 007.jpg
ID:	129033   Click image for larger version
Name:	Klein & Dayton 019.jpg
ID:	129036   Click image for larger version
Name:	Klein & Dayton 023.jpg
Old 02-16-2012, 04:09:29 PM
Tom Winland's Avatar
Tom Winland Tom Winland is offline
Banner Sponsor
Images: 8
Looks like you were running the Kline in the background of the third pic. looking good, hope to see the Dayton running this summer.
Tom Winland
Ohio
http://gasenginetom.com
CHECK OUT MY ENGINE VIDEOS AT
http://www.youtube.com/user/gasenginetom
Old 02-16-2012, 05:23:06 PM
Ye'll I remember it being hot and very humid that night, I didn't feel like doing anything cause the sweat was running out from under my fingernails, and that engine starts with very little effort, so it ran for about 4 hours that night and I just sat in the chair and watched and lessened to it run.............DH
  #33
Old 02-16-2012, 09:24:00 PM
Ironman Ironman is online now
Dave-
Did you take any pictures during the process of straightening the wheel on the engine cart? Did you use any heat on the wheel spokes?
Old 02-17-2012, 02:11:54 AM
Originally Posted by Ironman View Post
Dave-
No I did not get any pictures of it, Sorry. I left the wheel on the axle and then clamped the axle to the frame rail. I used a jack to push out the wheel and come along 180 around the other side to pull. I only moved it about 1" at a time. Then with the torch I heated each spoke to relieve any stress. and I did over and over till I got it where it needed to be. Don't do it in July when I did it, It was one hell of a HOT job to do. An old Amish men showed me how to it.........................DH
The Following 3 Users Say Thank You to BuckeyeMan For This Post:
  #35
Old 02-18-2012, 09:45:17 PM
Mike Lucius's Avatar
Mike Lucius Mike Lucius is offline
Images: 25
Dave, looks real good. If you have a minute would you mind posting what kind of primer and paint you're using? Thanks
Old 02-19-2012, 11:06:47 AM
jwx3 jwx3 is offline
Mike,
The products Dave has been using have primarly been from the Dupont ecomomy line of Nason and Dupont industrial coatings.
The bare to metal large pieces and castings he is using Dupont Industrial Coatings Corlar 2.1voc Mastic primer.
Its a great product, it can be sprayed or brushed on and can be used in temps as low as 35 degress f. but it takes a while to kick and dry but it does work very well and is reasonably inexpensive. Here is a link to the product data sheet.
http://pc.dupont.com/dpc/en/US/html/...orlar2-1ST.pdf
For small parts and small sheet metal parts he is using the dupont aerosol self etching primer, It's not for everything but real handy for small parts to prevent corosion and very convient as you dont have to break out a gun or worry about clean up and overspray.
http://dpcprd.asp.dupont.com/dpc/en/...013_AeroOV.pdf
For the top coat he has been using Nason fast dry Enamel, it does not use a catalyst, dries fairly quick and is durable.
We have been using a flattening compound in most of the paints we mix for dave . Dupont recomends not using a flattner in paints that do not use a catalyst , but we have been using a flattening agent from the Dupont industrial coatings line rk29000 with good success. Even though not recomended.
http://pc.dupont.com/dpc/en/US/html/...pcoat_IE_E.pdf
Hope this helps
Jim Washington
As for isocyanates
Drinkning untaxed likker and smoking cigarettes while painting is just as hard on the body.
You should wait until your done spraying for that stuff.
Old 02-21-2012, 09:53:32 AM
Images: 25
Thanks Jim, that's some real good information on paint and will help out a lot of folks here on Harry's.
The Following User Says Thank You to Mike Lucius For This Post:
  #38
Old 02-22-2012, 02:30:35 PM
Default Re: 1893 Dayton Serial #3 Outside for 101 Years
Armex baking soda 25.00 per bag
air compressor 9000.00
sodablasting equipment 10,000.00
dogging somebody over the
world wide web for freeloading PRICELESS
Name:	BORE SCOPE 037.jpg
ID:	129447   Click image for larger version
Name:	BORE SCOPE 038.jpg
The Following 10 Users Say Thank You to jwx3 For This Post:
  #39
Old 02-22-2012, 04:03:00 PM
Its good to have good friends with expensive toys, for those little jobs..............DH
The Following 4 Users Say Thank You to BuckeyeMan For This Post:
  #40
Old 02-27-2012, 03:15:38 AM
Here's an update on the restoration. The first thing I wanted to show was what I think is the reason the engine was stopped being used, and was left to sit.
All the Cams are held on the shaft with a set screw and a Tapper pin. When I was getting the engine apart I found that the Tapper pin on the center cam (witch is the one that trips the Ignitor) was missing, and you can see that the set screw was moving around on the shaft until the engine was so far out of time it would no longer run. There where also several places on the shaft all the way around where the set screw had been tightened up as they where trying to get it pack in time, with no luck I would say.
The other photos are of the cams before and after machining to remove the pitting. I was not going to get them all out, as some of them are very deep, so I did what I could to get them to look better. And the last photo is of the Fellows Gear shaper cutting the new cam gear...............DH
ID:	129830   Click image for larger version
ID:	129831   Click image for larger version
ID:	129832   Click image for larger version
Van Duzen 1893 3 1/2 HP Restoration Project -- page 8 Wayne Grenning Hit & Miss Gas Engine Discussion 36 06-22-2013 07:48:01 AM
Van Duzen 1893 3 1/2 HP Restoration Project -- page 11 Wayne Grenning Hit & Miss Gas Engine Discussion 24 12-15-2011 02:11:18 PM
Van Duzen 1893 3 1/2 HP Restoration Project Wayne Grenning Hit & Miss Gas Engine Discussion 0 07-05-2011 08:25:50 PM
Deutz Otto 1HP (French version) 1893 Lumenium Antique Engine Photos 6 04-06-2007 02:40:17 PM
