What parts do you need?
this thread has 1087 replies and has been viewed 162820 times
Old 07-05-2019, 02:54:50 PM
joder joder is offline
Default Re: What parts do you need?
Cylinder for an early upright Maytag.
Old 07-07-2019, 07:38:56 PM
Doone Doone is offline
Thanks, ArodaPowerCo, for the info on Wacker pumps. In searching for Wacker I stumbled across WASTECORP. Pumps. They show almost the same dimensions on the replacement diaphragms they sell for many different brands of pumps. Sent them my dimensions to see if they thought theirs would work. We'll see, and again, thanks for the help.
Old 07-08-2019, 07:20:51 AM
Vizer Vizer is online now
Images: 1
Looking for Olds parts and Nelson Brothers Engines parts
Old 07-08-2019, 10:46:05 AM
Dan Moore Dan Moore is offline
I need a rocker arm for a 1 1/2hp Sta-Rite, also need a piston for a 1 3/4hp Associated.
Old 07-08-2019, 05:18:46 PM
Scott Kocher's Avatar
Scott Kocher Scott Kocher is offline
a good usable piston for a 2 hp ihc vertical air cooled engine
Old 07-08-2019, 08:23:40 PM
noeleo noeleo is offline
Looking for Mag, trip, brackets to convert Economy 2-1/2E from coil/igniter back to magneto.
Old 07-08-2019, 10:18:39 PM
Greg Mosley Greg Mosley is offline
Need a needle valve and muffler baffle for a Model 1 1/2 Evinrude pump (circa 1916)
Old 07-09-2019, 11:29:24 AM
Rick Rohrs Rick Rohrs is offline
Are you looking for Webster set up? I might be able to help you out. This is for noeleo, economy
Old 07-09-2019, 11:51:49 AM
Joel Mosley's Avatar
Joel Mosley Joel Mosley is offline
Images: 27
Looking for a good Olds 3A piston. 5" diameter.
Old 07-09-2019, 12:18:42 PM
David Babcock David Babcock is offline
Would like to find n.o.s or replacement points for a 1275 delco light plant. Db.
Old 07-10-2019, 11:28:47 AM
Dale Russell Dale Russell is offline
Looking for a Crank for my Sandwich engine. Casting #255 Thanks for looking.
Dale
Old 07-11-2019, 06:20:42 PM
Images: 1
Looking for Olds parts ,2A engine cylinder and piston, And looking for Nelson brothers 1.3\4 up exhaust rocker arm.
Old 07-11-2019, 06:58:34 PM
Bigb Bigb is offline
I came across a Clinton motor corp 3 1/4 horse generator, looks very old but in freaking great condition but the word " sample " is written where the serial number should be on the plate, just shot in dark someone may know , thks
Old 07-11-2019, 08:49:35 PM
freshieslures freshieslures is offline
Hi, looking for a hopper, exhaust rocker, crank guard and 10" ball muffler to suit a 12 hp big chief engine. Thanks Justin
Old 07-12-2019, 11:14:29 AM
Bump! Still looking for a CRANK!
---------- Post added at 10:14:29 AM ---------- Previous post was at 10:13:09 AM ----------
Bump, bump.
Old 07-12-2019, 03:52:51 PM
hucksrl hucksrl is offline
Originally Posted by Gary Moss View Post
Thought it might be a good idea to start a thread with parts that fellow enthusiasts need to complete their projects. Maybe we can get some trading going!
I need rocker arm for a 1-1/2 hp Fuller & Johnson N and an original muffler for a 2hp ball hopper Monitor.
Let's get this parts party going!
Gary
Looking for a brass water valve bolt on an 1890 Deming Marvel pump and various other items like rebuild gaskets, a rubber washers (to valves). I would also like a manual and/or expanded parts diagram for that pump.
Robert Hucks, Lexington SC hucksrl@gmail.com
Old 07-12-2019, 10:47:00 PM
I have located a Crank for the Sandwich engine that I was looking for. Thanks Rick!
The Following User Says Thank You to Dale Russell For This Post:
  #1078
Old 07-29-2019, 09:08:16 PM
Michael Smallridge Michael Smallridge is offline
parts for a 1 3/4 hp little jumbo ignitor model..mike
Old 07-30-2019, 07:44:26 AM
Len Spoelman Len Spoelman is offline
Aermotor 8 cy dogbone gov style, need ignitor & trip, rocker arm, connecting rod. Thanks.
Old 07-31-2019, 06:02:16 PM
Greg-N-CA Greg-N-CA is offline
I need a flywheel mounted 16" pulley for a Fairbanks Morse Type T 6 HP engine.
I Need Parts Parts For (2A042) (MEP-017A) Raymond56 Military MEP and Aircraft Gen-Sets 7 10-27-2011 08:47:51 AM
1946 evinrude parts list & parts Lou Quirch Antique Marine Engines and Outboard Motors 2 12-16-2009 06:51:34 PM
Trade Delco 15c3 parts for 15c1 parts MBreen254 Generators & Electric Motors General Discussion 1 03-09-2008 06:59:22 PM
Online Onan Parts Sales-or at least a parts number B.Ikard Onan Generators 3 06-21-2007 07:07:12 AM
Fairbanks Morse type T parts list, parts. Mike Rollins Hit & Miss Gas Engine Discussion 1 11-18-2006 04:53:36 PM
