St Lawrence 3cyl, new crankshaft
this thread has 26 replies and has been viewed 5799 times
Old 03-22-2013, 04:37:34 AM
PaulGray's Avatar
PaulGray PaulGray is offline
Images: 38
Default Re: St Lawrence 3cyl, new crankshaft
Damn, that is impressive work, JB ! When I saw the first few pix, I was scratching my head as to how you were going to pull that one off... Certainly one of the best posts on the Stack in a long time. Bravo Sir.
The Following 2 Users Say Thank You to PaulGray For This Post:
Old 03-22-2013, 10:36:39 PM
Thanks Paul, hope to see you at Calvert.
Old 03-25-2013, 06:41:33 PM
Brian Triebner's Avatar
Brian Triebner Brian Triebner is offline
I found these pictures in our albums from England. While we were at the Anson Museum Geoff showed us this massive crank. He explained the same process was used of hot forging the throws together then heat up again to twist throws to suit.
Brian
ID:	161271   Click image for larger version
ID:	161272   Click image for larger version
ID:	161273   Click image for larger version
The Following 4 Users Say Thank You to Brian Triebner For This Post:
  #24
Old 09-23-2015, 08:36:59 AM
Peter Short Peter Short is offline
J.B.
Thanks for the crankshaft-making posts, including your recent two cylinder job, very interesting.
FYI, here is a photo showing a large crank being twisted at the English Steel Corp, Sheffield, probably in the 1950's.
Name:	Twisted crank.JPG
The Following User Says Thank You to Peter Short For This Post:
  #25
Old 09-23-2015, 09:02:51 AM
Here is another example of forged, twisted and machined crankshafts, they are three-throw water pumps built in 1879 by Easton Anderson and are most impressive not to mention mind-boggling, pieces.
This photo comes from The Steam Engine in Industry volume 1 by George Watkins and shows the well and surface force-pumps at Southampton Waterorks, Timsbury Station, England.
Quote: The crankshafts were splendid examples of smith's work, in wrought iron 9in diameter machined only for the pump rod bearings, which had a collar forged on either side of the brasses.
Name:	9 inch forging 1879 Easton Anderson small.jpg
  #26
Old 09-23-2015, 09:35:05 AM
wmusta wmusta is offline
How are your twists oriented in relationship to crank rotation? Example would be "does power stroke fire with the direction of your twist or against the twist?"
Old 09-23-2015, 11:06:20 AM
I didn't try for a particular direction, the engine is a reversible two cycle and can run either way.
St Lawrence engine GW Eddy Hit & Miss Gas Engine Discussion 15 04-30-2019 09:50:18 PM
Lawrence E. Porter, 92 markcorson Steam Stationary Engines, Traction Engines 0 08-23-2009 09:11:59 PM
Murray Tregurtha 3cyl Engine John C. Neagley Antique Marine Engines and Outboard Motors 1 04-10-2007 07:28:26 PM
Lawrence Woolf German George Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 33 03-02-2007 04:17:22 AM
David Lawrence Andrew Mackey Kohler Generators 1 01-09-2006 08:43:29 PM
