Webster engines, where are they all?
this thread has 82 replies and has been viewed 6232 times
Old 07-22-2016, 02:49:50 PM
MFaris MFaris is offline
Photo Webster engines, where are they all?
Hi everyone,
I'm curious how many Webster engines are out there, both inverted and horizontal. To my knowledge there is no list of existing engines so I thought this thread might be a good start! I would like to gather serial numbers, rough locations (ie state or province), type of ignition, and pictures if possible.
The attached photo's show Webster Improved Inverted sn 3812 located in BC Canada, it has spark plug ignition and is owned by myself and my father.
The Following 9 Users Say Thank You to MFaris For This Post:
Old 07-23-2016, 10:51:23 AM
brian harris brian harris is offline
Default Re: Webster engines, where are they all?
Here's mine # 1791
Also there's a thread started on the rebuild of this engine.
I also have a short list of sn# and owners (about 20) I have seen on the Internet
These are all inverted, here's the # I have ( I have more names than #s) but will start with the #s, names can be added if owners choose too or other info
Sn #
1058...friends I've seen..........Hot tube 3hp...Cast iron tag "V" crank
1791...Brian Harris................Hot tube 3 hp
2079.....................................hot tube 3hp
2584............
2587.......................... 2012 hilpipre auction
2624.....................................hot tube 3hp
3210......................................hot tube 3hp
3812....................................Spark plug ignition
4???......................................
?948.....................................
.................................................. ........Tate jones& co (tag) improved webster
The Following User Says Thank You to brian harris For This Post:
Old 07-23-2016, 12:57:45 PM
Great stuff Brian!
Hopefully we can get some info on the horizontal models as well.
It seems to me a fellow in North Dakota? mentioned a few years back that he found the remains of one in a scrap yard. I will have to go back in the archives and find that post...
Here's hoping a few more Webster owners will jump in!!
Old 03-31-2019, 09:29:30 PM
Byron Boike Byron Boike is offline
Hi my Webster is a tate and jones co. 3hp and ser. no. is 4498
The Following 2 Users Say Thank You to Byron Boike For This Post:
Old 03-31-2019, 09:56:09 PM
https://www.youtube.com/watch?v=lXkaFBnQsqw
https://www.youtube.com/watch?v=zUbdW1LcjV8
Old 04-01-2019, 01:31:04 PM
Sad Iron's Avatar
Sad Iron Sad Iron is offline
Best check with nar, seems to me there's a couple roaming around there.
And I expect Kenny Wolf still has a few.
There's at least one in Canada, I'd say it's an overgrown 4hp horizontal.
I've been calling it a "pre-improved" as it runs backwards and was built for a wipe spark ignition which Dad returned it to.
Serial # is 1534 if my memory is holding up.
J
**Also should probably check in with the owners of Thompson & Lewis engines as the horizontal Websters tended to follow that pattern**
The Following 2 Users Say Thank You to Sad Iron For This Post:
Old 04-07-2019, 12:05:16 AM
Inverted's Avatar
Inverted Inverted is offline
Some what funny as we just got done machining 3 sets of flywheels for the Inverted Webster Engines.
I have restored 4 of them and working on 3 more at this time. Also have helped several others get their's back to running condition. Have a couple of patterns and core box's for the 3 HP Inverted Webster's.
I may have some information from working on Websters and if anyone is interested contact me or I could start a thread on what I may or may not know on them.
Enclosing a couple of pictures of the machined flywheels and some of my Son running the big lath turning the center for the crankshaft fitting. - Ted m
ID:	332197   Click image for larger version
ID:	332198   Click image for larger version
ID:	332199   Click image for larger version
Old enough to know I won't get all the projects done that I have started BUT young enough to still think I can
Old 04-07-2019, 09:59:02 AM
Dwayne Fuller's Avatar
Dwayne Fuller Dwayne Fuller is offline
Wow, looks like you are a Webster guru. I had a Webster for many years but sold it about three years ago when I started downsizing my collection. I bought it from Paul Cox in Kentucky back in about 1991. He told me it was on a printing press in New York. It was a hot tube with no igniter. I got it running on propane with an Impco carburetor. It had the pulley cast with the flywheel. If I can find my pictures I will post a few and add the serial number. I sold it to a man in central Texas.
Old 04-07-2019, 04:33:48 PM
Brian Lynch's Avatar
Images: 23
Here's a 3hp inverted. This belongs to our county fair assoc. I've been working on this as time permits to bring it back to running condition.
ID:	332274   Click image for larger version
The Following User Says Thank You to Brian Lynch For This Post:
Old 04-07-2019, 06:51:12 PM
If this works there is a link to a short video of my Webster running.
https://www.smokstak.com/forum/showthread.php?t=60401
The Following 2 Users Say Thank You to Dwayne Fuller For This Post:
Old 04-07-2019, 09:56:08 PM
Fred Van Hook's Avatar
Images: 480
Photo Re: Webster engines, where are they all?
This one and a couple others are located in Peru Indiana.
https://youtu.be/qL6SePEjrE8
A Atheist will never be able to say, "I told you so!!"
Engine movies can be seen at: pileofiron
Old 04-07-2019, 11:16:16 PM
Here is an updated version of Brian's serial number list:
Sn #
1058...friends I've seen..........Hot tube 3 hp...Cast iron tag "V" crank
1214...Sold on Engine Ads......Hot tube
1534.....Somewhere in Canada........ Horizontal 4 hp
2065........Washington.........Tagged - Woodin & Little, S.F. Calif. Hot Tube 3hp
2584............
3812.......British Columbia............Spark plug ignition 2 1/2hp?
4498......Minnesota.......... Tagged Tate Jones & Co. 3hp
4603.......New York
.................................................. ........Tate jones& co (tag) improved website
Please keep the pictures, info, and serial numbers coming!
Old 04-07-2019, 11:52:43 PM
Inverted's Avatar
Fred: Do you by any chance have the serial number off of this Jr. engine?? Most of the smaller Webster's that I have seen are the later type and have an Ignightor. This one dose not. - Ted
Old 04-08-2019, 12:12:22 AM
Here's one that was for sale on engine ads a while back. Looks like 1214?
ID:	332311   Click image for larger version
ID:	332312   Click image for larger version
Old 04-08-2019, 12:31:14 AM
I'll add a current picture of mine # 1791. Wish I could say I got more done on it in the last couple years.
Old 04-08-2019, 09:24:35 AM
Images: 480
Sorry but I do not..It is in a collection in Peru Indiana. Kenny has several inverted engines. I believe I seen 3 Webster inverted and a couple other brands including a Master Workman 2 cylinder?? It was hard to tell what was there because everything is jam packed together..
Old 04-09-2019, 10:20:57 PM
Inverted's Avatar
Dwayne: By chance did you sell it to a gent named Butch?? I know he bought one down that way. Helped him with the original carb and fuel pump. Don't know if he ever got them on though.
Guru-- Don't think so but some experience as from working on them? I may be able to help and maybe not but will try.
This is why I like Harry's Page as one cannot only learn but sometime's help others with there restoration problems. It seams like one can learn a lot. I for instance learned that some of the Jr. Webster were not Ignightor type (which I thought were all Ignightor type). Also on MFaris Webster has different flywheels, crank, gov. weights and latch out collar. This I have never seen on other Webster's One thinks they know something and then from this form he learns something new.
Mfaris - I think it is great that you are starting a serial number list on Webster's The one # 2857 is here in Nebraska and I know of another in south central Nebraska.
These are the number's on mine
1496 - V crank (Restored)
2584 - Hot tube (working on)
4278 - Hot tube (working on)
4649 - Ignightor Hot tube (restored)
5735 - Ignightor - Hot tube (working on)
6791 - Original running and rare front Ignightor type single set of gears.
These along with 2857 are all in Nebraska.
I also sent one to Australia but can't find the serial number. I have the number some place and will post it if and when I find it. - Ted
The Following User Says Thank You to Inverted For This Post:
Old 04-10-2019, 07:41:03 PM
Well we're up to 21 engines and counting! It seems like Websters are becoming more common everyday
Does anyone want to take a stab at some mfg dates? If I'm not mistaken the range is 1896-1906...
Sn # - Location - Details
1058 - California - Hot tube 3 hp...Cast iron tag "V" crank
1214 - Unk location - Sold on Engine Ads......Hot tube
1496 - Nebraska - "V" crank
1534 - Canada - Horizontal 4 hp
1791 - California - Hot tube 3 hp
2079 - Unk location - Hot tube 3hp
2065 - Washington -Tagged: Woodin & Little, S.F. Calif. Hot Tube 3hp
2584 - Nebraska - Hot tube, restoration
2587 - Unk location - Sold at 2012 hilpipre auction
2624 - Unk location - Hot tube 3hp
3210 - Unk location - Hot tube 3hp
3812 - British Columbia - Spark plug 2hp
4278 - Nebraska - Hot tube, restoration
4??? - Unk location
4498 - Minnesota - Tagged Tate Jones & Co. 3hp
4603 - New York
4649 - Nebraska - Igniter/Hot tube, restored
5735 - Nebraska - Igniter/Hot tube, restoration
6791 - Nebraska - Original running and rare front igniter type single set of gears.
?948 - Unk location
Unk - Unk location - Tagged: Tate Jones & Co, photo on improved website
The Following User Says Thank You to MFaris For This Post:
Old 04-10-2019, 09:57:01 PM
Guru-- Don't think so but some experience as from working on them? I may be able to help and maybe not but will try.Ted
Yes, Ted. I sold my engine to Butch. He has done a wonderful job of making it a show piece. Thanks for helping him with the parts. I will keep hunting the serial number so we can add it go the list. There was a Webster factory winch engine in Austin, TX, but it left for parts unknown. Also a small Webster in Ft. Worth that belongs to a man in Kansas.
The Following User Says Thank You to Dwayne Fuller For This Post:
Old 04-10-2019, 10:45:56 PM
Webster # 1058 is in California. I can't seem to find a picture, but next time I see it I'll get a few pictures as it has few differences Than the later ones
Brian
Webster Mag Help David Erb Hit & Miss Gas Engine Discussion 15 10-10-2015 06:43:29 PM
Webster Inverted Gas Engine - Webster Mfg Co David Sundry Hit & Miss Gas Engine Discussion 3 01-15-2007 02:30:40 PM
webster DanR Hit & Miss Gas Engine Discussion 1 11-09-2005 09:00:37 AM
Associated/United engines with Webster magnetos Dick Webber Hit & Miss Gas Engine Discussion 12 09-29-2005 05:20:16 PM
Webster mag. Bob Smitko Antique Engine Archives 8 10-31-1999 12:24:03 AM
