A RARE find of a lifetime Schleicher Schumm inverted Otto
this thread has 74 replies and has been viewed 14275 times
Old 11-13-2016, 10:42:17 AM
JSWithers JSWithers is offline
Default Re: A RARE find of a lifetime Schleicher Schumm inverted Otto
Originally Posted by 21avery View Post
Thank Rik for the pictures of your engine .Mine and Mikes looks very similar to yours . Yours look much heavier then ours . would you consider yours throttle governed ? I am not sure about ours yet . Any green Ottos over there ? we did win the lottery when I found it . Thanks again Scott
Riks engine clearly shows a pendulum governor. I would say it is not throttling. His does work differently than yours because it is operating the gas valve where yours does not appear to.
Old 11-13-2016, 10:59:17 AM
Brian Triebner's Avatar
Brian Triebner Brian Triebner is offline
Found this on YouTube, I believe it's Rik's engine.
https://youtu.be/ccgvk_uJqqU
The Following 6 Users Say Thank You to Brian Triebner For This Post:
  #63
Old 11-13-2016, 03:27:18 PM
rik lemmens rik lemmens is offline
Hello Brain and motor friends
This is the motor.
He has indeed a pendulum governer on the gas valve.
Specifically, he pulls the valve open with a hook.
whether more green is over the river?
Our ancestors have the most in WW I and WW II melted down for guns.
But fortunately there are still some, in other colors too, note the second photo, left beside the name plate, This is a project I have retired.
Thank you so much for the nice comments
Rik
The Following 10 Users Say Thank You to rik lemmens For This Post:
  #64
Old 11-20-2016, 10:48:44 AM
Mike O's Avatar
Mike O Mike O is offline
I went up to Scotts place yesterday to visit and play with the Otto. Scott had made a nice base platform for it to sit on. We fooled around with the gas cock dialing it the proper amount of fuel and then we tinkered with the governor adjustment and were able to make the old girl run pretty well on the governor hit and missing.
Then after that we took the spark plug out and made up a quick little hot tube set up and used a plumbers torch and ran it for a bit on a makeshift hot tube.
Here are a couple of videos to see. If someone knows how to inbed them in my post rather then a link please feel free to do so.
Thanks Mike
https://youtu.be/O4hqfmFj71U
https://www.youtube.com/watch?v=FMXCBrL-M88
Old 11-20-2016, 11:13:30 AM
Target Driller Target Driller is offline
Thumbs up Re: A RARE find of a lifetime Schleicher Schumm inverted Otto
What a gem and running very nice on that governor!
The Following 2 Users Say Thank You to Target Driller For This Post:
  #66
Old 11-20-2016, 01:51:14 PM
Keven Withers's Avatar
Keven Withers Keven Withers is offline
Very nice! Running like an Otto should! I would leave that timer on the engine if you convert it over to hot tube. It is to nicely done. It may be possible to incorporate both plug and hot tube.
The Following 6 Users Say Thank You to Keven Withers For This Post:
  #67
Old 12-02-2016, 04:29:32 PM
RustySteele RustySteele is offline
Hi Mike, great find! I just picked up a bound volume of Scientific American from 1889, and found a small article with your engine pictured! Thought you`d like to see it, it`s from the October 12, 1889 issue so maybe you can find one, I`ll see if I can find another copy, if I do it`s yours.
ID:	269300   Click image for larger version
ID:	269301   Click image for larger version
The Following 4 Users Say Thank You to RustySteele For This Post:
  #68
Old 12-02-2016, 04:44:28 PM
Mike O's Avatar
That's Awesome Thanks for sharing
The Following User Says Thank You to Mike O For This Post:
  #69
Old 06-23-2017, 02:55:12 PM
For the most part, you must be very sure that the engine is on a solid stabil and heavy base. Pendelum governors are very sensitive to movement, and if the engine moves at all it can set up a rocking couple movement that can disrupt the governor action. Great find and nice to see it at Coolspring. Thanks so much for sharing your experiance with it.
Old 06-30-2017, 06:39:30 AM
This is a funny statement. We had a 4hp upright Otto marine engine with a pendulum governor. Do you think there was a little unstable movement with that engine...?
Old 06-30-2017, 03:05:41 PM
Jon Rozevink's Avatar
Jon Rozevink Jon Rozevink is offline
Engine Buyer
In my experience marine engines never have govenors.
Check out my engine videos at http://www.youtube.com/user/sideshaft08
I want to buy your engines, especially rare ones! http://www.sideshaft.com
The Following User Says Thank You to Jon Rozevink For This Post:
  #72
Old 06-30-2017, 04:35:00 PM
Backus did offer a portable engine probably in the teens. Their pendulum govs are pretty sensitive to shaking. Must have had to do a lot of blocking to get it to run okay.
Old 07-09-2017, 09:46:38 AM
I would say for the most part that is a true statement. And most were 2 cycle. But our 4hp Otto was a 4 cycle upright with a pendulum governor identical to the 3 other 3 1/2hp Otto verticals we have owned. The difference being it had a different base, a single heavier flywheel and a built on reversing gear for forward and reverse. It even had the normal fuel pump and overflow mixer set up. We showed it at Rollag for many years alongside a 3 1/2. It now resides in north central North Dakota. It was the only one we had ever seen and was last at Rollag in 2005 for the Otto Expo.
Old 07-09-2017, 09:21:58 PM
Engine Buyer
Gearless Olds were made as portables and had pendulum govs.
I'm not an expert in old marine engines but I've never seen one 2
cycle or 4 cycle with a governor... Not saying there isn't one out there but why would it have been even been made?
Old 07-09-2017, 09:58:28 PM
Marv in Minn's Avatar
Marv in Minn Marv in Minn is offline
my Frisco Standard 5 hp Marine with reversing clutch and flyball governor.
and a 10 hp Frisco Marine
ID:	286100   Click image for larger version
restoring old iron, hot air engines and modelmaker.
The Following 5 Users Say Thank You to Marv in Minn For This Post:
Schleicher Schumm & Co 2 HP Sn. 1102 Wayne Grenning Hit & Miss Gas Engine Discussion 5 03-19-2015 10:42:29 AM
1884 7 HP Schleicher Schumm Gas Engine Chris Epping Hit & Miss Gas Engine Discussion 187 11-26-2014 04:02:41 PM
1.3hp Inverted Schleicher Schumm Otto JWithers Hit & Miss Gas Engine Discussion 5 09-07-2014 11:01:57 PM
1884 Schleicher Schumm 10 H.P. video Fred Van Hook Hit & Miss Gas Engine Discussion 4 09-24-2013 07:23:59 AM
10 HP Schleicher Schumm Slide Valve Engine Restoration - Page 16 Wayne Grenning Hit & Miss Gas Engine Discussion 30 02-24-2013 08:24:06 PM
