(6) 400 HP Snow engines running- video - 1989
this thread has 11 replies and has been viewed 3315 times
Old 09-19-2007, 11:11:27 PM
Wayne Grenning's Avatar
Wayne Grenning Wayne Grenning is offline
Default (6) 400 HP Snow Engines - (4 ) running - video - 1989
This is a video that I though should be posted. It was taken in 1989 by Woody Sins ( New Hartford, NY ) during an unannounced visit by us to Heath pumping Station in PA. Back then this station was used 24/7. The video shows (4) of the (6) 400 HP Snow engines in operation pumping natural gas under full load. The engines are still at the facility but not run any more. It was a great moment to capture these machines on tape, especially running as it was designed to do almost 80 years prior with out modern improvements. They still used low tension ignition and ignitors !!!- As built 4 of the engines were set up as low pressure compressors and two as high pressure or ( second stage compression). It is my understanding they were installed between 1911 and 1915. Shortly the Coolspring Power museum will have a 600 HP version of these amazing machines erected and running.
Worth Watching !!!
http://www.youtube.com/watch?v=WGJhWu_ydfI
Last edited by Wayne Grenning; 09-20-2007 at 09:33:03 AM. Reason: correction in title
Old 09-19-2007, 11:16:51 PM
Eric M.'s Avatar
Eric M. Eric M. is offline
Default Re: (6) 400 HP Snow engines running- video - 1989
WOW, Thanks Wayne! This is amazing!
Old 09-19-2007, 11:37:34 PM
DirtbikePilot DirtbikePilot is offline
Holy good GAWD that is cool!!!!!!!!!!!!!!!!!!!!
Thanks for taking the time to post that!!!!!
Old 09-20-2007, 12:16:46 AM
Glad you enjoyed it. I thought it would be worth doing !!!
Old 09-20-2007, 12:36:15 AM
Harry's Avatar
Be sure to click through to YouTube.com and add your rating to this video. You must be logged in on YouTube to do so.
Did you know that you can rate threads here on Smokstak? See the attachment below...
Old 09-20-2007, 08:59:38 AM
John Merry John Merry is offline
Thanks Wayne-impressive to see them in motion-can't help but notice how clean the engine room is. A person could eat off that floor for sure!
Old 09-20-2007, 09:02:41 AM
bocephus_k6 bocephus_k6 is offline
Well done Wayne, you have preserved a few moments in time...
Regards,
Brian
Old 09-20-2007, 09:35:57 AM
John Davidson John Davidson is offline
eMail NOT Working
Thanks Wayne; That brings back memories from the time I went with the gang from Coolspring up to Heath Station in 1990s. The operator started one of the engines by baring it to just past TDC of one cylinder and opening the air and it started right up and ran it for a while. I specially remember going out and listening the sound of exhaust, each pipe had a different note. Down the basement was a stockpile of spare parts. All in all, it was a memorable time. I wonder if it is possible to do that again. Probably not as those engines have not run in a while and other concerns.
Old 09-20-2007, 09:41:45 AM
John, I am not sure the public is allowed there any more especially after the explosion they had several years ago. - Wayne
Old 09-21-2007, 09:03:21 PM
lotz60 lotz60 is offline
Awesome video cant wait to see the 600 run at coolspring. Does anyone know when they are planing on getting it running. Thanks Wayne
Old 09-21-2007, 09:42:42 PM
TheEngineGal TheEngineGal is offline
Oh what exploded? One of the gas lines?
Old 09-22-2007, 09:30:13 PM
Kaili, I am not sure what actually happened. My guess is that there was a leak of natural gas in the building and it ignited. I have not been to the building since but it is my understanding that many of the windows and part of one wall was blown out. I know that a couple of "Stackers" have been there since. Maybe they can shed some light or post some photos on this this. - Wayne
4449 & 8444 (844) Race up Cajon Pass 1989 - All Aerial Video. Railroads Railroads and Equipment 0 10-21-2018 03:34:15 PM
Myrick Eclipse Running In The Snow Jonah Close Oil Field Engines & Related Equipment 10 02-20-2014 10:28:07 PM
Perkins Water Cooled Vertical Side Shaft Engine Video (Built by Garland Jobe 1989) Gil Garceau Scale Model Engineering 13 02-18-2014 02:20:46 PM
Snow Engine Video shamethedevil Hit & Miss Gas Engine Discussion 11 02-21-2010 03:38:07 PM
600 HP Snow Engine Video Harry Antique Engine Photos 1 05-27-2007 08:23:51 PM
