Go Back   SmokStak > SmokStak® General Off Topic Discussion > Smokstak Canada
Smokstak Canada For Canadian Smokstakers to meet, greet and have local discussion.
Smokstak Canada
IHC 1.5 hp Type M Three Way Fuel Valve Selector
this thread has 5 replies and has been viewed 372 times
Old 06-21-2019, 10:29:27 AM
Vladnick Vladnick is offline
Default IHC 1.5 hp Type M Three Way Fuel Valve Selector
In the process of restoring a Type M 1.5 hp IHC that is missing the three way fuel selector valve. I plan on trying to turn a new brass one on the lathe but I cannot find any information on the dimensions of the valve or spring that is supposed to hold it in the carburetor. I would appreciate any information that you may have on this item and if anyone else has tried to make one.
V
The Following User Says Thank You to Vladnick For This Post:
Old 06-21-2019, 10:34:44 AM
casertractor casertractor is online now
Default Re: IHC 1.5 hp Type M Three way fuel valve selector
https://www.smokstak.com/forum/forumdisplay.php?f=5
Old 06-21-2019, 11:19:24 AM
Steve Kreiner's Avatar
Steve Kreiner Steve Kreiner is online now
Copy one of the other ones you have
The Following User Says Thank You to Steve Kreiner For This Post:
Old 06-21-2019, 12:10:48 PM
According to the original thread on his engine:
https://www.smokstak.com/forum/showt...ar#post1551469
I'm going out on a limb and guess he doesn't have another.
Vladnick, I have a 3hp engine that I could take measurements from, but I believe that the 1˝, 3, and 6hp engines all used different valves.
The Following User Says Thank You to Kirk Taylor For This Post:
Old 06-21-2019, 06:30:37 PM
Default Re: IHC 1.5 hp Type M Three Way Fuel Valve Selector
Hello Steve
Thanks the information, if it wouldn’t be too much trouble I would appreciate the measurements. I have made a couple of attempts at turning one on my newly restored lathe but I am still learning how to cut angles and such. So my measurements need refining a bit and measurements will take out the guess work. Any help is is much appreciated. Thanks
V
Old 08-07-2019, 04:40:06 PM
Mike Unwin Mike Unwin is offline
I took the selector valve out of my 1.5 engine and these were my measurements if they help .
length of taper section 1.653
length of straight 1
overall about 2.75 excluding the handle mount which is chewed up
diameter of bottom of taper .509
diameter of top .695
hole is .650 up from the bottom
all in Imperial
hope this helps Cheers Mike
The Following User Says Thank You to Mike Unwin For This Post:
Wanted - - IHC 3 way selector valve Vladnick Carburetors, Mixers, Fuel Pumps and fuel delivery 9 04-06-2019 09:15:15 AM
L634 Fuel Line Fitting Type Between Fuel Filter and Pump? Birken Vogt Onan Generators 4 08-22-2015 06:38:07 AM
2-71 loss of fuel pressure from fuel tank-check valve? or bad fuel pump? Walter J. Generators & Electric Motors General Discussion 18 08-24-2011 09:22:40 AM
What Type Valve is This Richard H. Gambrell Steam Stationary Engines, Traction Engines 3 01-30-2009 08:45:23 PM
Brass fuel selector valve/bowl BWegher Hit & Miss Gas Engine Discussion 3 09-12-2005 05:59:26 PM
