Oil Field Engines
Reid Question
this thread has 2 replies and has been viewed 998 times
Old 10-29-2017, 12:02:10 PM
Peter Holmander Peter Holmander is offline
Default Reid Question
Does anyone know what the bolt circle dimensions are on the reid flywheel flange where the drive for the sisterville clutch mounts? My engine is a 15 HP. Not sure if that makes any difference.
Old 10-29-2017, 04:55:11 PM
Default Re: Reid Question
A circle scribed through the centers of the bolt holes is ten and a quarter inches in diameter. The holes themselves are 15/16" in diameter. The inner six inch diameter portion of the hub is raised ~1/4" proud of the outer part of the flange.
Kirk
The Following User Says Thank You to Kirk Taylor For This Post:
Old 10-30-2017, 08:58:46 AM
Thanks Kirk. Your info is a big help.
Reid backfiring question Dustin D Ehli Oil Field Engines & Related Equipment 9 08-19-2015 07:22:05 PM
Reid 25 HP Question: Martin Gaudet Antique Gas Engine Discussion 6 03-31-2011 08:43:23 AM
Another Reid Question? Fred Van Hook Oil Field Engines & Related Equipment 7 06-26-2009 01:12:53 PM
Reid Question GBerry Oil Field Engines & Related Equipment 16 01-31-2008 08:16:37 PM
25 hp reid propane question Manuel Azevedo Oil Field Engines & Related Equipment 2 03-02-2006 10:13:34 AM
