Air Compressors Restoration, Repair and use of Shop and Industrial Air Compressors |
Pneumapower 35 Compressorthis thread has 4 replies and has been viewed 560 times
Do you have manuals for pneumapower 35? I have one and know nothing about them
except their from the 50's and I would assume they use 20w non detg. oil |
Sponsored Links |
I tried to post this earlier and failed, so try again. We have a large unit on a 4 wheel chassis, it has a Large 6 cyl Buda engine with a clone 6 cyl compressor hooked up via a over center clutch. I forget the model but it is a big unit . I need to get it going before the thing goes to ruin. I got it out of a cement plant and they used it to spray concrete on like silos and the like. I didn't get the spray kit as the guy thought it was worth it's weight in gold, so
I just got the compressor unit. Any books or parts still around? I don't totally understand the pressure governor and how it works, thing has a relatively small volume tank for the size unit. I kinda thought I could use it to run a steam traction engine here that needs a boiler, it has plenty of capacity if I can get it going. |
Replied to your PM.
Hey Jim Do you have gasket sets for the schramm 35 or a block to jug gasket& head gasket Mine has sprung a leak, looks like it's coming from the engine side between block and jugs. also does anybody know why I'm getting carbon out of the compressor side? Thanks Jpohn
I should have the gaskets, sets are no longer available.
Bookmarks |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | F o r u m | Replies | Last Post |
1950 & 1952 SCHRAMM 35 Pneumapower Compressors - Wisconsin VM4/VP4 | K-Tron | Wisconsin Engines | 22 | 06-21-2019 10:32:13 PM |
Emmerson Compressor Motor Needs Part to make compressor run again. | Kanoona | Air Compressors | 7 | 10-14-2017 06:49:36 AM |
Novo Air Compressor - HB Compressor? | BigGoomba | Hit & Miss Gas Engine Discussion | 3 | 10-30-2015 10:15:31 AM |
Leo compressor: Trying to identify a small compressor unit | MattFretwell | Unidentified Engines | 1 | 02-27-2012 07:01:50 PM |
Air compressor | Lyle Fall | Antique Engine Archives | 0 | 09-07-2004 08:46:08 PM |
