Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generac Generators (SEARS, etc.)
Generac Generators (SEARS, etc.) Restoring, maintaining and operating Generac generators.
Generac H-Panel 0f2815 versions.
this thread has 0 replies and has been viewed 113 times
Old 10-28-2019, 10:36:22 AM
BrianHaze BrianHaze is offline
Default Generac H-Panel 0f2815 versions.
I overheard a conversation and I am now curious. I've been told there were two different versions of h-panels made. Revision a through d? then e through h? And If you have one of the older ones, and you replace it with a new one, you need extra stuff to have it talk to the engine and such.
Is this correct and is there a tech bulletin that was put out on this I could read?
Also, I thought it was the board change that made the revision, since ive seen two different boards inside the panels. However that idea went down the tube as I found a revision G board, which had the same setup as the older version ones.
Generac SG035 E Panel Issue Fabick Cat Generac Generators (SEARS, etc.) 2 12-30-2014 05:34:42 PM
Generac E Panel Controller issues BrianHaze Generac Generators (SEARS, etc.) 3 12-05-2013 06:34:19 PM
Need Generac "C" Control Panel wiring diagram. timbart Generac Generators (SEARS, etc.) 9 12-07-2010 05:42:43 AM
Will a Generac 7000EXL work without the system control panel bobrob62 Generac Generators (SEARS, etc.) 5 04-28-2010 04:47:52 PM
Generac C Panel stone Generac Generators (SEARS, etc.) 1 11-19-2008 05:38:38 PM
