Todays find, Caterpillar Air Cooled
this thread has 52 replies and has been viewed 4010 times
Old 05-07-2016, 10:05:00 PM
Nevr-Enuf-Stuf's Avatar
Nevr-Enuf-Stuf Nevr-Enuf-Stuf is offline
Photo Todays find, Caterpillar Air Cooled
Acquired this engine today, was told it originally came off of a 1940s? Caterpillar pull type road grader, it was used to operate the adjustments on the grader instead of being manually operated. It is one seriously heavy beast. Im calling out Kris Golden for not sticking around to help me load it But in his defense he did "push" me a little into acquiring it, dont know if that was a good thing or not
Any info on this engine is greatly appreciated.
Patrick
ID:	253210   Click image for larger version
ID:	253211   Click image for larger version
ID:	253212   Click image for larger version
Old 05-07-2016, 10:07:09 PM
Default Re: Todays find, Caterpillar Air Cooled
A few more.............
Patrick
ID:	253214   Click image for larger version
ID:	253215   Click image for larger version
ID:	253216   Click image for larger version
The Following 5 Users Say Thank You to Nevr-Enuf-Stuf For This Post:
Old 05-07-2016, 10:08:47 PM
gootsch gootsch is offline
Very rare and well made.
The Following 2 Users Say Thank You to gootsch For This Post:
Old 05-07-2016, 10:18:27 PM
Im liking the oil bath and pre-cleaner, just like the one on my brothers 1945 Cat D2.
Patrick
The Following User Says Thank You to Nevr-Enuf-Stuf For This Post:
Old 05-07-2016, 10:24:55 PM
The engine spins over nice. It has a primer cup on the top side of the intake manifold elbow and a compression release lever on the side.
Patrick
Name:	DSCN4844 - Copy.JPG
ID:	253218   Click image for larger version
Name:	DSCN4842 - Copy.JPG
The Following 3 Users Say Thank You to Nevr-Enuf-Stuf For This Post:
Old 05-07-2016, 10:56:54 PM
Junkologist's Avatar
Very nice! I would love to have one of those in my barn.
Mike
SmokStak member #146
The Following 2 Users Say Thank You to Junkologist For This Post:
Old 05-07-2016, 11:14:41 PM
The mags gonna need a coil if anyone knows a source.
Patrick
Old 05-08-2016, 12:48:14 AM
coyote62ny coyote62ny is offline
nice engine for mag parts i would try marks magneto
Old 05-08-2016, 01:25:32 AM
Donkeypull Donkeypull is offline
That thing looks like a beast, and looks sweet. I'm guessing 16hp?
Old 05-08-2016, 06:16:03 AM
Elden DuRand's Avatar
Okay, I've looked at the pics but don't see any way to crank it.
How is it started?
[SIGPIC][/SIGPIC]
Take care - Elden
http://www.eldensengines.com
Old 05-08-2016, 06:35:22 AM
Marv in Minn's Avatar
Marv in Minn Marv in Minn is offline
How is it started?
i see a rope notch in the outer pulley groove.
restoring old iron, hot air engines and modelmaker.
The Following User Says Thank You to Marv in Minn For This Post:
Old 05-08-2016, 07:25:09 AM
mschreiber mschreiber is offline
very nice complete find, governors seem tobe the weak link. 1472 made for cats 3 largest pull type graders from 1932 thru 1940. yours is missing a shroud, no problem and easy to make. i don't quite understand how u start urs too? theres a cat collector in utah that knows all there is about these 800g engines. some were used as power units not on a grader but sold thru oil well supply companies. some ran on propane. they are cats smallest engine ever. and only second aircooled engine besides the aircolled tank engine for ww2. i think urs is a propane very rare only 1 maybe known in antique cat club! heres mine.
http://www.acmoc.org/bb/showthread.p...659#post146659
https://youtu.be/qKmGZ7gI3Jg
https://youtu.be/kBJoK3POfhA
they were a option on these type graders.
The Following 7 Users Say Thank You to mschreiber For This Post:
Old 05-08-2016, 10:03:36 AM
So this engine is a little older than first thought. The shroud missing that your speaking of, your talking about the one that appears to be on the side of the head/jug in your photo? I'll get some close up photos of the carb posted but I think you may be correct on it being the propane set up. The notch in the pulley was added (homemade) this was evident when I first saw it, I figured the engine was originally belted to a starter since the shroud is fully screened in. The guy I got the engine from said a guy had told him that he had seen others with a similar notch. Im starting to get even more giddy now then when I first acquired the engine
Patrick
Old 05-08-2016, 10:24:11 AM
Patrick
yes its around the rear of the jug and covers the rear of the head. its shown after 4:32 of the first video. its made of 3 pieces, spot welded together. i think i got another 1 from another 800g i got that could be loaned out for pattern. i pm'd u my number, great find.
Old 05-08-2016, 10:27:10 AM
Doug Tallman Doug Tallman is offline
Maybe you should call out Kris and give him a big hug for pushing you to buy it?? At least a good thanks!!
The Following 2 Users Say Thank You to Doug Tallman For This Post:
Old 05-08-2016, 01:01:46 PM
Lauren's Avatar
Lauren Lauren is offline
Here are some pictures of my Caterpillar Pull Grader another project not enough time.
ID:	253262   Click image for larger version
Collector of Fairbanks N
The Following 3 Users Say Thank You to Lauren For This Post:
Old 05-08-2016, 06:39:01 PM
The mechanicals look a lot like a 1950's Cat motor grader.
Old 05-08-2016, 06:45:19 PM
The carburetor is a Zenith 9548B 7B4718. Havnt been able to find any info about it much less any reference to it at all on the internet.
Patrick
ID:	253281   Click image for larger version
ID:	253282   Click image for larger version
Old 05-08-2016, 07:28:49 PM
that carb is slightly similar to the d2/4 pony carb. call these guys 2 see if that might be propane. u have a 4d s/n, according to cat historian the oil field power units used a 1n s/n prefix. (note last link in this post), if its propane i think its oil field supply application.
http://www.thecarburetorshop.com/Mar...ng_Numbers.htm
http://www.mcdonaldcarb.com
heres more info.
http://www.acmoc.org/bb/showthread.p...646#post115646
---------- Post added at 06:24:38 PM ---------- Previous post was at 06:11:44 PM ----------
Patrick
the 7b number is a cat part number, the other is a zenith part number.
---------- Post added at 06:26:49 PM ---------- Previous post was at 06:24:38 PM ----------
whats the engine s/n please?
---------- Post added at 06:28:49 PM ---------- Previous post was at 06:26:49 PM ----------
5.5 hp. @1600 rpm.
The Following User Says Thank You to mschreiber For This Post:
Old 05-08-2016, 07:53:08 PM
So your saying that if the carb is a propane application carb then this engine could have been an oil field engine with its fuel supply actually coming from the well?
Patrick
---------- Post added at 06:50:22 PM ---------- Previous post was at 06:43:39 PM ----------
In that ACMOC link you posted thats clearly a gas carb.....Marvel Schebler?
Patrick
---------- Post added at 06:53:08 PM ---------- Previous post was at 06:50:22 PM ----------
It could be that my engine is missing its rope start pulley, as shown on your engine.
Patrick
Todays find...Champion No.1 Nevr-Enuf-Stuf Farm Antiques and Collectibles 4 12-11-2014 10:46:13 PM
Todays Find AKMark Hit & Miss Gas Engine Discussion 6 04-15-2014 09:09:16 PM
Todays Garage Sale Find Jon Rozevink Steam Stationary Engines, Traction Engines 7 05-03-2010 04:03:37 PM
Todays find. 4 workers and a toy steam engine. uppercanada Scale Model Engineering 8 03-31-2009 07:14:50 PM
Todays Find Charliehd Hit & Miss Gas Engine Discussion 2 01-11-2007 12:06:00 AM
