Briggs Model Y Serial No.
this thread has 48 replies and has been viewed 7496 times
Old 09-30-2015, 12:29:59 PM
Bolens Bolens is offline
Default Re: Briggs Model Y Serial No.
Hi I have picked one up. I don't have pics yet but it is complete and not too bad looking. It is black with some original decals still on it.
Type 60109
Model Y
Serial Number 288556
I hope to get it cleaned up and running. I would prefer to keep it original since a lot of the paint is still on it. The flywheel cover has the most paint, the kick start and actual engine don't have much paint on it. I will post some pictures after I take some.
Old 10-01-2015, 08:13:09 AM
Here is a few pictures of my small engine. I hope to get it running at some point.
ID:	235787   Click image for larger version
ID:	235788   Click image for larger version
Old 10-03-2015, 10:06:00 AM
BST BST is offline
I have 2 Y's ser# 33333 and ser# 306792
Old 10-03-2015, 11:15:27 AM
TekNik TekNik is offline
I bought my model Y this year.
It is No. 282179.
It is currently not running. The kick starter clutch is stuck, the exhaust valve is stuck and there is no fuel tank.
Has anyone disassembled the kick starter clutch and have pictures of how it goes together?
Oh, and how is the check valve in the fuel line set up?
Thanks,
TekNik
Old 10-03-2015, 05:18:30 PM
GaryH GaryH is offline
This link to the parts list at the ASEC site should will give you a breakdown of the starter clutch.
http://www.asecc.com/data/briggs_str...PL-Model-Y.pdf
The check valve bottom piece with the screen, if it is still there, should be a press fit and has a ball or disc inside. Try soaking the lower end first in spray carb cleaner in something that the cleaner will not eat through like a pill bottle. It may free up any stuck parts. You will get a rattle if it frees up.
If you do end up taking it apart be careful to not loose the ball or disc.
Gary
Old 10-03-2015, 06:35:36 PM
Thanks Gary,
The check valve is gone then.
Thanks,
TekNik
Old 06-15-2018, 04:32:47 AM
Metalmatt Metalmatt is offline
I know this is a really old post but figured I'd chime in anyway. I've got a 1936 model y type 60148 that is exactly 600 away from BST's! Mine is serial number 307392.
Old 06-15-2018, 09:44:39 PM
Mike in NC's Avatar
We have two more Y's in our collection. Serial numbers 38396 (1933) and 125731 (1935).
SmokStak Member #28
Old 06-03-2019, 11:34:13 PM
Mike in NC's Avatar
And just added another one. 219897
1935 Briggs Y Video
SmokStak Member #28
Briggs Model 14 202010 Serial 9107 crank Small Air Cooled Gasoline Engines 7 10-29-2018 09:47:48 AM
Briggs and Stratton Model N serial number Plate DBFarms Small Air Cooled Gasoline Engines 0 07-02-2012 02:00:47 PM
Briggs Model I Serial # Plate cleaning Zim Small Air Cooled Gasoline Engines 2 12-10-2011 06:53:19 PM
No Serial # On My 1945 Briggs Model N abriggsman Hit & Miss Gas Engine Discussion 2 02-20-2011 12:24:43 PM
Briggs Serial # WildIrishman52 Small Air Cooled Gasoline Engines 1 11-05-2008 09:57:12 PM
