Onan Small Gas Engine runs without sparkplug
this thread has 43 replies and has been viewed 8813 times
Old 08-07-2006, 02:16:40 PM
ardenlester00 ardenlester00 is offline
Default Re: Onan Small Gas Engine runs without sparkplug
Would you believe that "horse's patoey" is still keeping us in the dark. At first it was fun - now I want the spark to jump from his pointed head as I put it between the upcoming cylinder and the top of the head (his head).
I think you all are hitting on it as close as we can get - it the bolt was insulated, that would definitely work - and, I think, that the spark will jump if it first jumps from the sparkplug wire a short distance to the block (to not lose much voltage) and then from the pointed bolt to the cylinder as it approaches top dead center.
The observation that the spark plug is OVER the top of the cylinder and not the valves is a key here also, I would think. It would certainly help.
Perhaps the "geru" (not anymore in my book) will stop being so "cutesy" and give us what he observed in the engine someone brought to him to demo this.
In the meantime, i think our heads have created a logical answer - and it's been too hot for me to go out and duplicate it - when it cools off!
Hey, you folk are good sports - this has been fun (except for horse's geru)
Dennis
Old 08-07-2006, 11:38:26 PM
Daniel Sinsapaugh Daniel Sinsapaugh is offline
Hello iam reading this post and the the one with the sparkplug wire sitting on the head is possible. but iam sure it would run like a hit and miss. but if you look at that onan generator i posted that will run on one cylinder, starting cold. because its got one set of points. to run both cylinders.and when i was working on getting it going i forgot to put one of the wires on and she still fired up and ran. plus my thoughts is the head gaskit is not perfect solid ground. . try it out on some lawn mower it meight work as long as there is nothing conected to the head. thats my opion DAN
Old 08-15-2006, 09:36:07 PM
lucas34 lucas34 is offline
Originally Posted by Sky
other then this idea ( IM STUMPED ) i was thinking, sence there are no wires going to the plug, (lets use a points and condencer engine for my instance) so instead of hooking the main lead from the condencer to the magneto like normal, you just simply shorten the wire and put a terminal on it and hook it to one of the screws that hold the points cover on, but then your grounding the whole ignition system you might think, but, maybee not? were there is gas there will be an explosion if there is a ignition sorce near by, so even though the ignition system wont shock you the way it would be hooked up now, becouse the whole engine becomes the ground now, and now, the spark is looking for the shortest destance to jump, perhaps in the cylender?
sorry for the tardynes in this reply but i lost the page and just found it agen.
but im a little confused all ive ever ben tought about electricity was that it sirches for the shortest and most unubstructive whay back home (weather it be ground or the + to - side of a batery) so how does puting a conector on the main wire and solidly conecting it to ground work. thanks dont mean to step on any ones toes.
Old 08-15-2006, 11:14:28 PM
We don't know yet the real answer. The "geru" is being the south end of the north going horse.
Grounding the spark plug wire will short it right then - that won't work. But, if you allow the spark to jump a very short distance, it will still have enough voltage to travel and jump a second time - maybe from the pointed bolt in the spark plug hole to the piston at near top-dead-center.
That's as far as we are so far.
Dennis
Onan 15.0 JC, Engine runs but no electrical output Carter Onan Generators 8 11-26-2017 11:00:47 AM
Onan 4K Microquite KY series RV generator runs, stops, over speeds, stops, runs etc. WHallTN Onan Generators 13 01-09-2017 09:26:13 PM
REO Small Engine Question About CH Wendel Note Book Paint Color For REO Small Engine clgill57 Small Air Cooled Gasoline Engines 4 12-26-2013 04:09:20 PM
Onan 305CCK3N1A Serial # 82C696378 . Engine runs but no electricity. Jim Gramke Onan Generators 9 11-20-2012 03:06:42 PM
Onan W2C Sparkplug sqm1 Onan Generators 9 04-19-2009 02:04:03 PM
