I don't know what model Briggs this is.
this thread has 46 replies and has been viewed 4496 times
Old 06-02-2009, 06:31:04 AM
Jimmy's Avatar
Jimmy Jimmy is offline
Default Re: I don't know what model Briggs this is.
Here is a picture of the crank that is in question:
Anyway, I bought a N.O.S. crank and connecting rod for a WI. Since the WI crank does not have a bearing, I'll just cross the number on the current one, buy a new one, and have it pressed on by a machine shop. It's a long shot for true compatibility, but the crank was cheap (money wise) so I figured I'd give it a try.
Old 06-02-2009, 10:26:05 PM
Mike in CA Mike in CA is offline
Briggs still sells the bearing, it is #99158. It is not exactly like the old one though. The original bearing had a shield on one side and the new ones do not. I am not sure if that would be a problem.
Old 06-06-2009, 10:53:27 PM
41Briggs 41Briggs is offline
i never would have thought of that. but thankfully my old 41 WI runs perfect and i have put a few hours of runtime on it with no issues and no smoke! so it has a good working pump allright
Old 06-12-2009, 07:04:18 AM
Jimmy's Avatar
Does anyone have the part number for the breather?
EDIT: Make that the part number for the cast starter cup and the breather...
EDIT #2: SBreeden: could you post the type number for your engine?
Old 06-14-2009, 05:11:54 PM
SBreeden SBreeden is offline
Hello Jimmy, Sorry it took so long but the type # is 25177, and serial # is 187984.
The Following User Says Thank You to SBreeden For This Post:
  #46
Old 10-07-2009, 07:29:35 PM
Jimmy's Avatar
So I had the crank turned down 0.010" to .740" to remove the scoring and then had a friend chop off 0.010" of the connecting rod end cap and its counterpart and then reem it out to match the crankshaft. It works as a temporary fix, but I'd still like to get a good crank for the engine. Does anyone know if a crank from a model I would work? Both my WIBP and an I have the same bore and stroke plus each use ball bearings... so would they be the same? Or am I overlooking something?
Old 10-07-2009, 10:34:53 PM
trashman6062 trashman6062 is offline
Sorry for the post, did not see the end thread
Last edited by trashman6062; 10-07-2009 at 10:39:58 PM. Reason: Did not see the end thread
Briggs & Stratton Model 6 (model N) army DAF Small Air Cooled Gasoline Engines 5 11-04-2010 07:27:15 AM
Briggs Model A J Kocak Small Air Cooled Gasoline Engines 5 03-23-2009 10:33:31 PM
Briggs Model PB Crank (For Moto-Mower Detroit Model) Jonathan Widelo Small Air Cooled Gasoline Engines 0 02-05-2009 02:43:17 PM
Briggs engine model W series and Y model Travis Small Air Cooled Gasoline Engines 1 02-01-2009 08:58:41 PM
New guys needs help with Briggs model Z and model KR IHfan Small Air Cooled Gasoline Engines 7 06-16-2008 08:43:19 AM
