Briggs Model Q Teardown
this thread has 37 replies and has been viewed 1172 times
Old 06-14-2019, 08:06:17 PM
Junkologist's Avatar
Default Re: Briggs Model Q Teardown
I would definitely keep the WA. Consider this. I can’t remember, but I currently have six or seven Q models, but have only ever found one WA.
SmokStak member #146
Old 06-15-2019, 10:10:47 AM
Mike Stroz Mike Stroz is offline
Originally Posted by Junkologist View Post
I would definitely keep the WA. Consider this. I canít remember, but I currently have six or seven Q models, but have only ever found one WA.
I think I'm definitely going to keep the WA and sell the Q as parts/repair. How much do Q's usually go for? This one is is nice shape overall except that the rod doesn't spin on the crank as easily as it should. Probably easy to ream it out but I don't have the tools to do that.
The Following User Says Thank You to Mike Stroz For This Post:
  #23
Old 06-15-2019, 09:16:39 PM
I just noticed a Model Q on EnginAds that evidently does not have a low oil seized, snapped and brazed rod. Maybe could get that and combine the two?
Old 06-16-2019, 09:09:08 AM
That one is actually mine, the repair on the rod actually looks really nice and is definitely usable with a little work. I'd have no problem running it. Did any old Briggs rods have some sort of coating around the crank area? I'm second guessing it was actually brazed back together because if it was repaired, it was really well done
Old 06-16-2019, 11:28:06 AM
You know what, I know exactly what happened. The rod was replaced at some point with one that fir but wasn't quite the same so they brazed the oil slinger onto the rod cap and made the oiling hole. That makes perfect sense since the rod isn't the correct part number
Old 06-16-2019, 03:37:35 PM
Mike in NC's Avatar
You should just keep them both. You can always keep the Q on a shelf for a later time.
SmokStak Member #28
Old 06-16-2019, 05:07:45 PM
I might, but I could use the money since the transmission in my car just went, and I'm already almost out of space
  #28
Old 06-19-2019, 12:59:36 PM
What kind of oil should I be running in these? It says Mobil Gargoyle sae 20 is recommended, but would something like 10w40 be fine? I know not to run synthetic, only conventional in these old engines
Old 06-19-2019, 01:00:50 PM
Mike in NC's Avatar
I run SAE 30 wt. non-detergent in our engines.
SmokStak Member #28
Old 06-19-2019, 05:56:40 PM
I run SAE 30 wt. in our engines.
But would there be any downside to running modern 10w40 or something? I can't easily get sae 30 around me, I usually buy it a little at a time for my Maytags and 30's Evinrudes
Old 06-19-2019, 06:20:13 PM
Mike in NC's Avatar
Detergent oils suspend dirt in the oil to be filtered out by a filter, which these engines do not have. Non-detergent oils let the dirt fall to the bottom of the oil pan.
SmokStak Member #28
Old 06-21-2019, 02:00:34 PM
Ok that makes sense. I'll see if I can buy some in bulk.
On another note, I was messing with the carb on the WA (Tillotson M18a) and I realized the one jet (low speed I think) was screwed all the way in and the other was the only one being used. Does anyone know how far out I should turn the screws? I usually start at around 1.5 turns each for most engines but this one I have no idea, the one jet was about 3/4 turn out and the other was screwed all the way in
Old 06-21-2019, 03:22:38 PM
uglyblue66 uglyblue66 is online now
Once you have the carb clean and all else is ready to go,set both screws at 1.5 turns out from a gentle closing.
The new chinese repop carbs have a issue with the high speed jet,the lower 1, being screwed in to tight and when you adjust it,you actually bring out the large high speed needle from inside the carb. I also had trouble with a needle having a edge on it,causing it to stick.
So even new 1's have faults.
---------- Post added at 03:22:38 PM ---------- Previous post was at 03:21:16 PM ----------
check with Walmart in the oil section close to where the chainsaw bar oil is and so forth.I think the 30weight hd oil is beside of it..They carry a non detergent 30weitght oil in the super tech lable.Seems to work on the stuff I use it on.About any oil now adays is cleaner than the oil was back then.
Old 06-21-2019, 04:55:00 PM
Perfect, thanks. I also gapped the plug a little tighter and that helped too. I did run it a while and it started squeaking so I shut it down. Not sure what that could be, maybe something rubbing or it overheating? Still ran exactly the same even with the squeak, and it's only got a hair of slop in the rod. No metal in the oil so probably not anything catastrophic. I'll pull the flywheel and make sure the condensor I put in didn't come loose or something.
Old 06-21-2019, 08:50:16 PM
Just took the oil pan off and checked inside, it looks almost new. Turns out the slight slop was between the cam and crank, the rod has a really small amount of scoring on it but too small to catch a fingernail so I just put it back together. The cylinder has a really small amount of scuffing but I've been happy running much worse. Neither flywheel is rubbing anything either so I really have no idea what was squeaking. Any ideas? You can't hear anything just turning it over. Maybe a stuck ring? There was more oil in the cylinder than I would expect.
Old 06-21-2019, 10:23:33 PM
Mike in NC's Avatar
Mike, Try this.
Tune-Up Information
SmokStak Member #28
Old 06-22-2019, 10:59:31 AM
Mike, Try this.
Tune-Up Information
Thanks, I'll print that out for future reference. Retorqued the rod bolts, adjusted the valves, and cleaned the valves off. Now my squeak is gone and it's purring like a kitten. I can't believe how smooth it is, especially for a huge single cylinder!
  #38
Old 06-22-2019, 12:18:43 PM
gdstew gdstew is online now
This is what B & S recommended
The Following 2 Users Say Thank You to gdstew For This Post:
Model 82 Teardown Question kleinkaliber Maytag Engines and Collectibles 2 12-06-2015 12:52:25 PM
Little crawler teardown wilson Ross Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 11-26-2010 01:09:21 PM
Cam timing after teardown gruby26 Small Air Cooled Gasoline Engines 3 01-18-2009 09:21:11 AM
Tecumseh H30 teardown and overhaul squarend Small Air Cooled Gasoline Engines 9 05-10-2008 11:35:27 PM
