What parts do you need?
this thread has 1097 replies and has been viewed 164395 times
Old 07-31-2019, 06:34:06 PM
J ohn J ohn is offline
Question Re: What parts do you need?
Fairbanks Morse Z 15 hp Cylinder & Piston / conn rod
Name:	FM Z 15hp b.jpg
Old 08-03-2019, 09:53:26 PM
Kevin Weis Kevin Weis is offline
Default Re: What parts do you need?
Mogul JR side plate, intake and exhaust valves and springs, fuel line to carb check valve. Thanks.
Old 08-10-2019, 07:21:47 PM
johnrod johnrod is offline
Default What parts do you need?
need:
1 or 2 flyweights for a 1 3/4 hp Economy XK governor.
hinged gas cap for a Stover 2 hp KA.
Ex. rocker arm for a Stover 2 hp KA.
Ex. pushrod for a 2 hp. Witte throttler.
thanks
Rod in AZ
Old 08-16-2019, 09:10:22 PM
addition to the above post.
I need 2 flyweights for the Economy [1 3/4hp]. also the complete spindle and spring.
thanks Rod in AZ
Old 08-16-2019, 10:23:21 PM
DustyEngine DustyEngine is offline
10hp ihc M flywheel
IHC vertical mixer, igniter, fuel pump, and igniter trip parts
Thanks!
Old 08-17-2019, 01:12:54 AM
Joel Mosley's Avatar
Joel Mosley Joel Mosley is offline
I need a rocker arm, rocker arm stand and a complete igniter trip for a Nelson Brothers model P engine. Thanks
Old 08-17-2019, 10:30:14 AM
Vizer Vizer is offline
Looking for 2A Olds cylinder and piston,
Also looking for Simplicity 6hp parts, rocker arm stand .
Old 08-19-2019, 02:28:50 PM
joder joder is offline
Still searching for a useable, early upright maytag cylinder - drilled for a primer cup.
Old 08-23-2019, 09:09:24 AM
Gene Fisher's Avatar
Gene Fisher Gene Fisher is offline
Mixer float/bowl for early Edwards engine must be in working order.
Old 08-27-2019, 07:21:04 PM
Emt18967 Emt18967 is offline
ihc 6 hp sleeve,head,fuel pump
Old 08-27-2019, 07:59:20 PM
Richard Hunt Richard Hunt is offline
I'm looking for a magneto gear for a Fairbanks Morse Z 15 HP. I think it is part number ZEA142A. It's a 33 tooth gear. I'll buy the mag too if its on one.
Old 08-27-2019, 08:07:24 PM
Gil Garceau Gil Garceau is offline
Lamp cage for early old Homelite 120 v DC generator.
Thank you in advance
Gil g789456 at optonline. net
For this:
My youtube channel: http://www.youtube.com/user/reddrryder/videos
The Following User Says Thank You to Gil Garceau For This Post:
  #1093
Old 08-29-2019, 04:47:02 AM
Garak Garak is offline
Fairbanks Morse 3hp 'Z'
I'm looking for a muffler with 1 1/2" stub pipe.
Old 08-31-2019, 10:08:29 AM
Jeff P Smith Jeff P Smith is offline
Need mag bracket for 1915 Alamo, cast in number 6748, raised numbers 1-7 hp 1041, for a Wizard Mag.
Would consider a broken one as long as it would be repairable and not been welded on before. Thanks, Jeff
Old 09-04-2019, 11:25:54 PM
Gary L. Naylor Gary L. Naylor is offline
Looking for valves for a FBM Jack Jr or info on a possible substitute.
Also a piston and rod for a FJ farm pump engine.
Old 09-05-2019, 10:04:31 AM
Trevor Alder Trevor Alder is offline
Looking for a push rod/cam bracket for a 1 3/4 Mogul. Also an exhaust hose for an upright Maytag.
Old 09-05-2019, 05:17:37 PM
rafekc rafekc is offline
I am needing a 2-bolt intake valve cage for a early 3A Olds like the one in this picture.
Original or unmachined casting would be fine.
Thanks...
Rafe
Name:	olds 3a intake cage.jpg
Old 09-05-2019, 06:58:59 PM
Woody Sins's Avatar
Woody Sins Woody Sins is offline
Looking for a muffler to a 5HP Standard, like the one in the picture, but 2" pipe.
I Need Parts Parts For (2A042) (MEP-017A) Raymond56 Military MEP and Aircraft Gen-Sets 7 10-27-2011 08:47:51 AM
1946 evinrude parts list & parts Lou Quirch Antique Marine Engines and Outboard Motors 2 12-16-2009 06:51:34 PM
Trade Delco 15c3 parts for 15c1 parts MBreen254 Generators & Electric Motors General Discussion 1 03-09-2008 06:59:22 PM
Online Onan Parts Sales-or at least a parts number B.Ikard Onan Generators 3 06-21-2007 07:07:12 AM
Fairbanks Morse type T parts list, parts. Mike Rollins Hit & Miss Gas Engine Discussion 1 11-18-2006 04:53:36 PM
