B&S Winco 2700w, Fine Tuning & Parts Source?
this thread has 6 replies and has been viewed 339 times
Old 05-25-2019, 09:32:22 PM
Millsy Millsy is offline
Default B&S Winco 2700w, Fine Tuning & Parts Source?
I fell into a '72 Winco 2700 Watt generator with I believe a 23 Cu in Briggs and Stratton engine. It is a lovely piece of equipment. And I know nothing about it.. so any and all information is welcome.
B&S Model 233481
Type 0284-01
Code 7209251
Winco 2B07PS-3t/1
I've gotten it running by cleaning the carb, and for the most part it runs very well... But I am wanting to 'super tune" a slight hunt out of the no-load idle... at present it hunts up and down just slightly. ( the governor opens the throttle blade just a touch about every 2-3 seconds) I've spent some time adjusting the needle valve, which seems to effect the fuel mixture most when under a load, or accelerating. I've played with the Idle valve and got most of the hunt out of the engine... But it is still there, and this is my first attempt at working on a small engine,
Next question: the foam air filter crumbled into a paste of green smoo, Where can I go looking for a replacement?
Last question: The generator has what looks like a 1970's auto (foot) dimmer switch just above the receptacles, what is it for & any idea where i can get an owners manual for the generator and engine?
Thanks, Jason
The Following User Says Thank You to Millsy For This Post:
Old 05-25-2019, 10:15:11 PM
Default Re: B&S Winco 2700W, fine tuning & parts source?
My guess that dimmer looking switch is for starting the engine using the generator to crank it. Some you hook up to a battery and some models you plug into 120V AC house current.
Old 05-25-2019, 11:01:38 PM
Ken Karrow Ken Karrow is offline
Check plate on generator for dc voltage rating, that will tell you voltage for battery for cranking. Any b&s dealer should have/get air filter element. Napa may can get it as well. Most small engines are happier when running a little rich in fuel, New filter element may help running as well.
The Following User Says Thank You to Ken Karrow For This Post:
Old 05-25-2019, 11:36:35 PM
Vanman Vanman is offline
Other cause of no load hunting is worn throttle shaft and / or other vacuum leaks...
Got any pictures? I have a 2 kW, 1959 Winpower / Briggs model 23 set. Runs at 1800 rpm, and also is electric start. Quite a nice unit.
Old 05-25-2019, 11:53:17 PM
Thanks fella's. I will try richening the mixture a bit more, and see what happens.
It is a 12 volt starting motor, as I believe it is painted on the positive starter post on the generator. I've been using a rope, as I don't want to tie up a battery, and thus I have not payed any attention to the electric start set up.
I will snap some pictures and figure out how to post them here. Yes this is also a 1800RPM unit.
The Following 2 Users Say Thank You to Millsy For This Post:
Old 05-26-2019, 08:35:24 AM
Bruce Dorsi Bruce Dorsi is offline
Default Re: B&S Winco 2700w, Fine Tuning & Parts Source?
The foam air cleaner element is B&S # 270093.
The 2334xx engines are 9hp.
Most generators have a slight hunt under no load. ....Seafoam additive for the fuel has helped a lot of times.
You could try sending an e-mail to: service@wincogen.com to see if they can supply an owner's manual.
The Following User Says Thank You to Bruce Dorsi For This Post:
Old 05-26-2019, 11:35:34 PM
Thank You Bruce! I will contact Winco tomorrow.
I have managed to tweek and tune my way to a dead smooth idle.. really happy with the results, even if I don't really know what I did.. just kept fussing with the two carb adjustments.
Now to figure out how to post pictures.
Fine tuning a Stickney Harry Terpstra Hit & Miss Gas Engine Discussion 13 05-01-2019 04:25:32 AM
You`ve Got To Expect A Bit Of Fine Tuning. BUT! WaterlooBoy2HP Garden Tractors and Mowers 13 10-02-2011 09:34:46 PM
Fine tuning the Onan 4.0 CCK derone Onan Generators 11 09-29-2010 03:33:44 PM
Fine tuning 4.0 CCK Ben Cowan Onan Generators 7 07-03-2009 11:37:56 PM
Winco Parts Source JBittnerSr Generators & Electric Motors General Discussion 0 08-25-2007 11:22:03 AM
