Briggs & Stratton FE or Early FH Gallon Base Video
this thread has 5 replies and has been viewed 506 times
Old 06-06-2019, 10:55:17 AM
Mike in NC's Avatar
Default Briggs & Stratton FE or Early FH Gallon Base Video
Here is a short video of the engine running.
Briggs FE or early FH Video
SmokStak Member #28
The Following 9 Users Say Thank You to Mike in NC For This Post:
Old 06-06-2019, 10:21:04 PM
ulgydog56's Avatar
Default Re: Briggs & Stratton FE or early FH Gallon Base Video
running sweet...…...
The Following User Says Thank You to ulgydog56 For This Post:
Old 06-07-2019, 12:30:15 PM
enginecrzy enginecrzy is offline
Wow nice engine!!
did it need much to get it going?
The Following User Says Thank You to enginecrzy For This Post:
Old 06-07-2019, 10:13:20 PM
Mike in NC's Avatar
The guy I got them from said he has had them for over 20 years and the Y only ran once or twice. The F series he never heard run. I got both of them on Monday and Tuesday got the Y running and Wednesday got the F series running. I had to fill both with oil. Filed the points and added gas. Both needed some carb adjustments but I think they both sound pretty good.
SmokStak Member #28
The Following User Says Thank You to Mike in NC For This Post:
Old 06-16-2019, 11:40:00 AM
Everett Hayden's Avatar
Everett Hayden Everett Hayden is offline
Really nice MotoMower FH. That runs great Mike. Looks like it may be missing the thick gasket behind the crankcase vent. Congratulations on
a nice find.
The Following User Says Thank You to Everett Hayden For This Post:
Old 06-16-2019, 01:55:59 PM
Mike in NC's Avatar
Default Re: Briggs & Stratton FE or Early FH Gallon Base Video
Thank you Everett.
The breather is broken, but I think I have a line on a replacement one.
The base on this one has 2 holes on each ear instead of just one hole.
SmokStak Member #28
Found An FH and an FE both gallon base grega Small Air Cooled Gasoline Engines 4 07-02-2016 10:28:42 AM
FE #9009 gallon base grega Small Air Cooled Gasoline Engines 2 07-19-2014 11:43:16 AM
Briggs and Stratton N with odd base Jeff Townsend Small Air Cooled Gasoline Engines 4 12-15-2011 09:17:36 AM
Early Maytag gallon can with paper label. Tony Glaser Maytag Engines and Collectibles 3 10-02-2010 10:51:05 PM
Briggs & Stratton Z base Stevie Mote Small Air Cooled Gasoline Engines 0 10-21-2004 02:49:57 AM
