BSA 120cc Stationary Engine Service Manual
this thread has 3 replies and has been viewed 386 times
Old 06-25-2019, 04:42:53 AM
squaretree24 squaretree24 is offline
Default BSA 120cc Stationary Engine Service Manual
First time user on this site so hope this message works.I have a vintage howard rotary hoe powered by a BSA 120cc engine.The piston is beyond repair so i am hoping to acquire a copy of a service manual to get the dimensions and get one made or purchase one in good condition if available.Will measure bore size once i have original specifications.Tried to find details under vintage engines in this site but no luck.Thanks in anticipation Doug.
Old 06-25-2019, 01:47:52 PM
Philipagri Philipagri is offline
Default Re: BSA 120cc Stationary Engine Service Manual
I have attached (I hope) the information you require from an old BSA instruction manual. The 120cc engine is called the BSA model C. Let me know if you need further information from the manual, I've never actually worked on one of these engines.
Name:	BSA manual.jpg
ID:	337861   Click image for larger version
Name:	BSA manual engine specs.jpg
The Following User Says Thank You to Philipagri For This Post:
Old 06-26-2019, 07:05:13 PM
Thanks for your reply.I will now measure bore size and see if i can locate a new or used piston that will be serviceable.If anyone can advise me where i can download an exploded view of the BSA 120cc engine from, it will be appreciated
Old 06-29-2019, 06:11:12 PM
The Engineer's Avatar
The Engineer The Engineer is offline
hi sent you an email regarding piston
cheers john
Lawnboy C Engine Service Manual TractorDom Small Air Cooled Gasoline Engines 1 07-12-2016 06:25:14 PM
48 gm 6-71 engine service manual pete36330 Vintage Diesel and Oil Stationary Engines 6 05-07-2015 12:21:02 AM
Kohler L600/654 Engine Service Manual Available garys 68 Kohler Generators 2 12-20-2014 02:07:48 PM
Need Service Manual for Kholer Engine L600 evincent Kohler Generators 8 07-12-2009 10:11:06 PM
small engine service manual Bill Sherlock Antique Engine Archives 2 12-19-2001 11:39:24 PM
