B&S 124700 Model Series Charge Armature
this thread has 2 replies and has been viewed 319 times
Old 06-25-2019, 08:26:43 PM
radiodoc radiodoc is offline
Default B&S 124700 Model Series Charge Armature
Has anyone here rewound a B&S charge armature coil? If so, would you happen to know the wire gauge of the magnet wire needed? Thanks.
Old 06-25-2019, 11:34:33 PM
K-Tron K-Tron is offline
Default Re: B&S 124700 Model Series Charge Armature
Why bother, the Briggs 590454 coil is extremely common and very cheap.
Chris
The Following User Says Thank You to K-Tron For This Post:
Old 06-26-2019, 01:07:48 PM
K-Tron I just thought it might be interesting diversion. I have repaired several that had a bad diode or capacitor in past years. I believe this is the first one I have run into that the coil was burned up. Over the weekend I purchased a late eighties to early nineties DR trimmer/mower for 20 bucks at an estate yard sale. Didn't take much to get it running but the battery charge armature was toast. I've ordered the part. I always try to tell the owners to first not jump start the engine or if they must be sure to disconnect the charging wire. I appreciate your comments.
Solar Charge Controller to Charge Generator Battery Cav Onan Generators 28 08-18-2017 11:58:06 AM
JD Model 60 Series Combine dadam2308 Farm Antiques and Collectibles 3 03-08-2016 10:52:50 PM
Armature and coil for Briggs Model "B" grampsh Magnetos, Ignition Coils and Spark Plugs 5 11-25-2013 02:09:58 AM
Sumpter Model 12 Magnet charge Jim Gorter Magnetos, Ignition Coils and Spark Plugs 3 08-26-2010 06:13:04 PM
Briggs engine model W series and Y model Travis Small Air Cooled Gasoline Engines 1 02-01-2009 08:58:41 PM
