1-1/2 HP Economy
this thread has 8 replies and has been viewed 606 times
Old 08-05-2019, 12:48:53 AM
Eng42 Eng42 is offline
Default 1-1/2 HP Economy
Hi, I have this 1922 economy. I have not run it for years and am having trouble getting it running, It will fire once when I give it a shot of starting fluid. How far should I turn the valve on the mixer, and do I put the choke plate all the way closed?
Old 08-05-2019, 07:17:58 AM
d huling d huling is offline
Default Re: 1-1/2 HP Economy
My 2 1/4 has to run with the neddle valve open about 3/4 turn and the choke all most closed. It is hit miss all most the same for my 7hp
Old 08-05-2019, 08:03:06 AM
R Shannon R Shannon is offline
Check valve may be stuck. Not pulling fuel up from tank. Choke with hand until fuel runs out mixer.
Old 08-05-2019, 10:53:54 AM
Thanks for your replies. I was thinking it may be a problem with the check valve. I'll take it apart and clean it.
Old 08-05-2019, 01:40:01 PM
VicF VicF is offline
My engine runs full choke and maybe 3/4 turn on the needle valve. But my engine needs work. It runs rich and runs slow Waiting for parts from Hit n miss enterprises.
Old 08-08-2019, 08:53:02 PM
I got the check valve out and cleaned it up. Still would not start so I removed the fuel tank to clean it up. The filter was plugged up. I had forgotten that about 30 years ago when I got the engine I found the tank in poor condition with lots of pin holes. I cleaned it as best I could and slathered Bondo all over it. It worked at the time but apparently the Bondo is deteriorating and I need a new tank. Who makes them for the 1-1/2 HP engine?
Old 08-08-2019, 10:32:35 PM
Dale Russell Dale Russell is offline
Check with with John Wyant. He is a sponsor here on this site. He does good work I hear.
Old 08-15-2019, 10:30:13 PM
Ok, Thanks. He has everything loaded up for the Portland show, so he'll get back to me after that.
---------- Post added at 07:30:13 PM ---------- Previous post was at 07:15:28 PM ----------
It still won't start, so I am working on a process of elimination to fix problems. First I pulled off the points and magneto assembly. I filed the points. When I put it back together do I need a special gasket material?
The Webster Tripolar mag seems to have a weak magnet. I have a huge magnet I can use to re-magnetize it but I have to get it off or at least partly disassembled so I can reach the ends of the magnets. Is there anything to look out for when disassembling it?
Old 08-16-2019, 03:42:49 PM
Got the magnet off with no problem and re-magnetized it. Have good spark now.
Economy 6hp xk daveinmo Carburetors, Mixers, Fuel Pumps and fuel delivery 11 12-04-2014 01:08:39 AM
Economy 6hp XK daveinmo Hit & Miss Gas Engine Discussion 7 10-07-2014 09:24:48 PM
Economy S 13/4 Swanstone Carburetors, Mixers, Fuel Pumps and fuel delivery 2 07-17-2014 10:30:19 PM
6hp Economy in todays economy MarkBillesbach Hit & Miss Gas Engine Discussion 3 05-21-2011 11:15:24 PM
5 HP Economy L.D. Antique Engine Archives 3 01-21-2003 12:34:23 AM
