Modern Carb's on old Engines...
this thread has 2 replies and has been viewed 326 times
Old 08-15-2019, 02:54:37 PM
BiggCheese777 BiggCheese777 is offline
Default Modern Carb's on old Engines...
Just a quick question and a thought, has anyone ever used a modern carb. on an old throttle gov'n engine. I have no experience with these engines but was wondering if it was ever done before. Either small engine or small automotive one lunger carbs not talking hot rodding, just making it run more smoother and reliable...?
Old 08-15-2019, 03:12:00 PM
Email NOT Working
Default Re: Modern Carb's on old Engines...
I have seen different carburetors installed only when they couldn't find the original. But I don't believe any kind of a modern carburetor with floats, needles and seats, diaphragms, gaskets, o-rings, Etc is going to be more reliable then a good old lunkenheimer or any simple fuel mixer with no moving Parts but a needle valve.
Old 08-15-2019, 04:24:47 PM
A freind of mine put a Briggs 8hp carb on a Fairbanks 3hp engine and it did fine.Just looked like a pokey dot on Lady Libertys rump.Way out of place.BUT the engine was running and not stuck in the barn because of no carb.
The Following User Says Thank You to uglyblue66 For This Post:
Modern Stirling Engines Brent Rowell Hot Air Engines 5 11-02-2018 07:56:03 PM
Help: Modern Carb for 3hp/80232 Briggs 57briggs6b-s Carburetors, Mixers, Fuel Pumps and fuel delivery 1 07-13-2018 08:30:45 PM
Modern Gas Engines (1893) joelr4 Hit & Miss Gas Engine Discussion 2 10-11-2013 12:36:50 PM
Modern Gas vs Old Carb & Fuel Pmp MEP017 tsdp Military MEP and Aircraft Gen-Sets 4 05-06-2013 01:43:10 AM
what modern uses do you have for your old engines? agusta74 Hit & Miss Gas Engine Discussion 22 09-06-2012 10:46:31 AM
