Ohio pushrod engine info needed.
this thread has 6 replies and has been viewed 447 times
Old 08-15-2019, 08:36:35 PM
bryanb1138 bryanb1138 is offline
Default Ohio pushrod engine info needed.
I have recently purchased what appears to be an Ohio push-rod type engine. I have found little to no information for this type engine on the internet. Is there any one out there with any info on these types of engines? I am trying to figure out the horsepower because there is no tag. The bore is 7" by 9" stroke with 34" flywheels. It looks very similar to the 3 hp that is on youtube only much larger. If anyone can help, it would be greatly appreciated.
Thanks, Bryan
The Following User Says Thank You to bryanb1138 For This Post:
Old 08-15-2019, 09:18:42 PM
Mike Monnier's Avatar
Hoarder
Default Re: Ohio pushrod engine info needed.
Bryan, it's at least 8 hp. Info on these engines is scarce and sometimes contradictory. I have an undated brochure listing 1.5, 3, & 6hp engines. The 6 is listed with 28" flywheels and 6x8 bore & stroke. I also have a copy of a 1915 Joy brochure showing 30" flywheels with a 6x9 bore & stroke for a 6hp engine. I've seen one 10hp engine; but do not have dimensions for that engine.
Old 08-16-2019, 01:17:34 PM
CBarth66 CBarth66 is offline
I have a 6 hp. Ohio pushrod, or Joy, or Buckeye or something! As you can see I can't find much info on them either. I'm taking it to the Portland Indiana show, so maybe someone will share information on it.
ID:	341565   Click image for larger version
The Following User Says Thank You to CBarth66 For This Post:
Old 08-16-2019, 04:49:54 PM
Bryan: Here is a thread on my Ohio pushrod that may have some information of interest .
https://www.smokstak.com/forum/showthread.php?t=142628
Make a new friend today, and a lot on the way through . Paul-"OLDIHC" #227
My YouTube channel : https://www.youtube.com/user/njoldihc
Old 08-16-2019, 08:47:48 PM
Thanks to all for the help! The gentleman that I got it from thought it might be a 9 hp.The engine is VERY heavy and has a sub base. I will try to post some pics soon.
Thanks again!
Old 08-18-2019, 01:55:04 PM
Here are some photos.
ID:	341684   Click image for larger version
ID:	341685   Click image for larger version
The Following 3 Users Say Thank You to bryanb1138 For This Post:
Old 08-18-2019, 03:44:34 PM
We were also able to find a serial number stamped on the top of the cylinder boss just below the hopper behind the head. It is #6134
2 or 3 hp Ohio pushrod engine video Tom Sampson Hit & Miss Gas Engine Discussion 3 01-14-2013 11:00:42 PM
Info Wanted On A 1 1/2 hp Joy, AKA "Ohio Pushrod" Henry Macomber Hit & Miss Gas Engine Discussion 15 12-30-2012 05:34:09 PM
Austral pushrod engine information needed David Nicolson Smokstak Down Under 0 07-12-2011 02:03:04 AM
3hp Ohio pushrod Mike Monnier YouTube Old Iron Videos 4 06-29-2010 08:58:31 PM
Ohio pushrod 6 h.p. original color. Jim Cook Hit & Miss Gas Engine Discussion 2 08-20-2009 03:16:16 PM
