Fuel Line Sizes 1-1/2 M
this thread has 0 replies and has been viewed 162 times
Old 08-18-2019, 09:35:11 AM
northern1926 northern1926 is offline
Default Fuel Line Sizes 1-1/2 M
Hello (again), I was wondering what size diameter fuel lines are used originally on my 1926 M (gas) engine? The one that runs from the pump to the carb was replaced (quick fix repair) with a 1/4" line. I noticed the line from the tank to the pump is 1/4", and appears original. The drain line that runs from the bottom of the carb is larger than 1/4", and has a flared type fitting to the carb. This appears to be original too. The 90 degree brass fitting (feed) was replaced with a straight fitting. I guess my main concern is the proper size line and fittings from the pump to the carb. Thanks!
F-M fuel line BillMN Hit & Miss Gas Engine Discussion 3 03-08-2016 03:21:51 PM
L634 Fuel Line Fitting Type Between Fuel Filter and Pump? Birken Vogt Onan Generators 4 08-22-2015 06:38:07 AM
Filtration: Fuel Strainer? Anyone have a Photo of F/M fuel-line FUEL STRAINER? DerekC Hit & Miss Gas Engine Discussion 1 11-17-2007 06:10:01 PM
Need fuel line(s) for DJC tierramaya Onan Generators 3 06-08-2007 04:56:41 PM
Fuel Line Fred Van Hook Antique Engine Archives 1 11-11-2003 10:05:35 PM
