Help with Stover CT2
this thread has 5 replies and has been viewed 292 times
Old 08-19-2019, 11:58:45 AM
Stakeside Stakeside is offline
Default Help with Stover CT2
How much oil in Stover CT2 and what type to use?
Are there any manuals available for this engine?
The Following User Says Thank You to Stakeside For This Post:
Old 08-19-2019, 12:45:34 PM
stufforbud stufforbud is offline
Default Re: Help with Stover CT2
Manuals are available and they won't tell you how much oil to put in the crankcase. There is a drain plug and a fill level plug so you will know when you have enough oil. If I remember right, it's less than a quart.
Good luck, Bud
The Following 2 Users Say Thank You to stufforbud For This Post:
Old 08-21-2019, 01:13:23 PM
Still looking for source of a manual for the for the CT2. Anyone have an idea?
Old 08-21-2019, 01:18:46 PM
www.hitnmiss.com
Old 08-21-2019, 02:30:17 PM
Click on "Sponsors" at the top of the SmokStak page. It will take you to the business cards of people offering goods and services.
Starbolt Engine Supplies, Lee Pederson, and Hit and Miss Enterprises all list the Stover CT manual in their on-line catalogs. There is a link to each vendor's website on their respective business card.
Old 08-22-2019, 02:51:59 PM
In short: drain out old oil. Re-install drain plug. remove upper level plug and add SAE 30 oil slowly, until oil flows out the upper hole. re-install plug and you are set. remember to oil all outside oiling points: valves, rockers and linkages. READ Kirks post - he gave excellant advice!
Stover 1 1/2 hp K Bob Hanauer Hit & Miss Gas Engine Discussion 12 06-12-2010 05:42:55 PM
Stover 1 1/2 Keith Imhoff Antique Engine Archives 0 08-20-2003 12:46:12 PM
Stover CT-2 Bill Antique Engine Archives 2 08-20-2003 01:14:33 AM
Stover 1 1/2 hp John Ackermann Antique Engine Archives 0 08-16-2003 12:08:00 PM
Stover Patrick M Livingstone Antique Engine Archives 4 08-11-2003 02:21:36 PM
