Stover 2 1/2 hp hit and miss engine
this thread has 2 replies and has been viewed 233 times
Old 08-20-2019, 02:59:23 PM
miczilka miczilka is offline
Default Stover 2 1/2 hp hit and miss engine
I opened the crankcase compartment of this engine for inspection and found inside of the piston on the wrist pin a loose bolt with a cotter key through it. What is the purpose of this loose bolt and cotter key? I fear this bolt will get dislodge and do damage in the crankcase. Has anyone had this issue? Please advise.
Old 08-20-2019, 05:04:20 PM
Default Re: Stover 2 1/2 hp hit and miss engine
The bolt is supposed to anchor the wrist pin to the piston, to keep it from moving side to side in the piston wrist pin bore. The cotter pin is supposed to keep the bolt from coming loose. Remove the piston and check that the pin bushing is OK, and in place. Remove the cotter pin and tighten the bolt, then replace the cotter pin.
Old 08-20-2019, 05:44:17 PM
Thankyou Andrew for the advice. I will remove the piston and check the wrist pin. Mike
Stover CT-3 is my First Hit and Miss Engine highbeam Hit & Miss Gas Engine Discussion 18 02-03-2018 10:53:55 PM
Stover Hit and Miss engine coil help mbaldwin Magnetos, Ignition Coils and Spark Plugs 4 07-25-2017 05:49:11 PM
Stover 1/4 hp hit miss engine David Schmidt Hit & Miss Gas Engine Discussion 22 02-20-2016 02:18:25 PM
Stover V Hit and Miss Engine George Taylor Hit & Miss Gas Engine Discussion 9 05-05-2012 11:45:00 AM
Need help with Stover Rex hit miss engine Jacob WI Hit & Miss Gas Engine Discussion 20 09-04-2009 08:42:11 AM
